How do I fix apps not showing up to use as default?
Nathan 20 Reputation points
2026-09-01T22:22:50.0533333+00:00
Apps such as Zen, MPV or VLC will not show in the default apps selection at Settings > Apps > Default Apps.
I am aware I'm able to change default apps for Files but it still forces me to use Edge when opening links. This is after a fresh windows 11 install, and I have switched from my old E-mail account to my new one which I believe caused the issue.
Windows for home | Windows 11 | Apps
Marcin Policht 107K Reputation points MVP Volunteer Moderator
2026-09-01T22:47:16.51+00:00
Try one of the following options:
Option 1: Re-register the apps via the installer
Because Windows protects file-type associations under the new user profile, the cleanest way to get Zen, MPV, or VLC back into the main Settings > Apps > Default apps list is to trigger their registration entries again. Download the latest installer for the application and run it. If the installer provides options such as "Install for all users" or "Register file associations," enable the appropriate option. This can recreate the registry capabilities entries that Windows 11 uses when populating the Default apps list.
Option 2: Use the manual "Open with" method
If the application still does not appear in the main Settings list, you can assign it to individual file types through File Explorer. Right-click a file, such as an .mp4 or .html file, select Open with, and then choose Choose another app. Select VLC, MPV, or Zen, enable "Always use this app to open [file extension] files," and click OK. Repeat this for each file type you want associated with the application.
Option 3: Use a third-party open-source tool
A command-line tool SetUserFTA (Set User File Type Associations available at https://setuserfta.com/) or a GUI equivalent Default Programs Editor (available at https://defaultprogramseditor.com/)
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
0 additional answers
