Need help with writing an Excel formula
MargieA 40 Reputation points
2026-09-01T15:23:18.7+00:00
Columns A and B represent a range. Trying to write a formula that will look up the amount in Column F, to where it falls between (or equal to) A and B, and return the % from Column C into Column G.
Jay1 Tran 605 Reputation points Independent Advisor
2026-09-01T15:46:42.3366667+00:00
Hi MargieA,
Thank you for reaching out.
From what you've shared, the formula provided by the AI is correct. However, each value in Column A contains a trailing hyphen (-), which causes Excel to treat the values as text rather than numbers. As a result, the formula will fail when attempting to compare the value in Column F against the ranges in Columns A and B.
To make the formula work, please remove the trailing hyphens from Column A. If you need to keep the hyphens, please reach out again, and I’ll be happy to help modify the formula accordingly.
Thank you for your time and patience.
AI answer
2026-09-01T15:23:34.24+00:00
In G2, use a range-match formula like this:
=XLOOKUP(1,((F2>=$A$2:$A$100)*(F2<=$B$2:$B$100)),$C$2:$C$100)
Then fill the formula down column G.
How it works:
  • F2>=$A$2:$A$100 checks whether the value in F2 is greater than or equal to the start of each range.
  • F2<=$B$2:$B$100 checks whether it is less than or equal to the end of each range.
  • Multiplying those two tests returns 1 only for the row where F2 falls within the range.
  • XLOOKUP returns the matching percentage from column C.
If the value in F2 might not match any range, use:
=IFERROR(XLOOKUP(1,((F2>=$A$2:$A$100)*(F2<=$B$2:$B$100)),$C$2:$C$100),"")
An equivalent alternative is:
=FILTER($C$2:$C$100,(F2>=$A$2:$A$100)*(F2<=$B$2:$B$100),"")
1 additional answer
  1. MargieA 40 Reputation points
    2026-09-01T16:52:56.7033333+00:00
    Accepted
    Thanks!
