How to quote part of a text in another place in Word
Saint/112 40 Reputation points
2026-08-31T11:25:05.0966667+00:00
Hello everyone!
I don't know the name of the feature I am looking for so I couldn't find it in the Help.
In a document I am writing I want to enter the date on the first page and have it displayed on the footers. It must not be the current date, it has to be the quotation of a fixed character chain.
TIA
Regards
Nick
Microsoft 365 and Office | Word | For home | MacOS
Stefan Blom 351.3K Reputation points MVP Volunteer Moderator
2026-08-31T12:37:09.4933333+00:00
At the location in the document where you want to type in the date, apply a unique paragraph style, meaning a style which is not used elsewhere in the document.
In the footer, add a STYLEREF field which references the style name.
1 additional answer
  1. Marcin Policht 107K Reputation points MVP Volunteer Moderator
    2026-08-31T12:26:51.01+00:00
    Looks like the feature you are looking for is called a Document Property field, which is often used through Quick Parts. It lets you enter a text string or date once and then display that exact same string elsewhere in the document, including in the footer. Because you are storing the date as a document property rather than using Word's DATE field, it remains fixed and does not automatically change to the current date.
    The easiest method is to use one of Word's built-in document properties. On the first page, place your cursor where you want the date, go to Insert > Quick Parts > Document Property, and select an appropriate property such as Publish Date or Subject. A placeholder will appear; enter your fixed date, such as October 24, 2026.
    Then double-click in the footer to open it. Go to Insert > Quick Parts > Document Property and select the exact same property you used on the first page. Word will display the same date in the footer. If you subsequently change the date in the document-property field on the first page, the footer will reflect the change as well.
    If you want the date to be a fixed character string and do not want Word treating it as a date at all, this approach is particularly appropriate. The key is to use the same Document Property in both locations, rather than inserting Word's automatic DATE field.
    If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    hth
    Marcin
