Managing tabs, address bar, and search settings in Edge on Windows 11
So, in all honesty, I accidentally downloaded something sketchy and it messed up my laptop for a bit, but I uninstalled it now, but it still hasn't fixed the initial opening of edge and now it just looks so weird. Basically, if you ever used a Chromebook every time you open chrome it took you to the main search screen and that's what edge did but not it doesn't even if the sketchy app is uninstalled and I need a little bit of help.
Best regards, Eddie.
AI answer
The behavior shown is consistent with Edge opening but not rendering the normal start page correctly. Since a sketchy app was previously installed, use this order of fixes:
If Edge still opens to a blank or broken page after these steps, use Settings and more > Help and feedback > Send feedback.
That does not look like Edge new tab page. There must be an app or an extension that replaces it. First, I would suggest you run a manual scan using Windows Security as suggested from the AI response. Open Windows Security, go to Virus & threat protection > Scan options. Select Full scan then proceed to clicking Scan now.
If the results did not detect anything, can you click the puzzle piece icon next to the star icon in the address bar and check whether there is an unknown extension installed?
