Installing or updating Microsoft Edge on macOS
On a Mac running macOS 12.7.6 (Intel), Microsoft Edge was automatically updated from 150.0.4078.105 to 152.0.4191.53. After the update, Edge no longer launches.
Environment
What happened
Edge 151 and later require macOS 13. This Mac cannot be upgraded past macOS 12, so any 151+ build leaves it without a working browser.
What I have tried
Questions
Hi Liu Dongmiao
Since the issue occurs immediately after upgrading from Edge 150 and reinstalling Edge 150 restores functionality, the problem may be related to compatibility between newer Edge builds and macOS 12.
As forum participants, we do not have access to Microsoft Edge engineering systems and cannot determine why a specific update was offered to your device or whether this behavior is expected.
I recommend contacting Microsoft Edge Support and providing:
You can start here: Microsoft Edge Support
Only Microsoft support or the Edge team can confirm the intended update behavior and whether a servicing issue exists.
Hope you'll get this cleared out, feel free to update here if anything comes up!
You're not doing anything wrong here. Edge 150 was the last version that runs on macOS 12 (Monterey). Starting with 151, Edge needs macOS 13 (Ventura) or newer, per Microsoft's own docs.
The problem is the updater on Mac it doesn't check your macOS version before installing anything. It just grabs the latest release, even if it can't run on your machine. That's why it pushed you to 152, and Edge stopped opening.
There's no setting that keeps you on version 150 specifically. The closest thing is to turn off automatic updates entirely, which has the same practical effect. You do this by installing a small preference file that tells the updater not to check for updates. If your Mac is managed through something like Jamf or Intune, this is straightforward. If it's not centrally managed, it's harder to get it to stick reliably.
Keep in mind that freezing on 150 also means no more security updates for Edge on that Mac, since Microsoft has already ended macOS 12 support past that version. It'll get you working again in the short term, but it's not really a fix.
It's also worth checking whether that specific Mac model can actually take a newer macOS version than you think.
