comultrus.co.in has infected my home page with Norton and McAfee ads since a Windows Edge upgrade.
Patrick O'Hagan 20 Reputation points
2026-08-29T22:18:12.3566667+00:00
comultrus.co.in popups are constant on the right side of my screen. They are full of fear-inspiring phrases, such as 5 viruses found, TROJAN found in /Win 32 or system error! The pop-ups cannot be shut down without another popping up within seconds. If the pop-up is clicked, a McAfee or Norton web offer is opened.
Microsoft Edge | Other | Windows 10
_AW_ 69,121 Reputation points Volunteer Moderator
2026-08-29T23:36:39.9633333+00:00
Those are likely push notifications coming from Microsoft Edge.
Open Microsoft Edge and copy/paste the following into the address bar then click enter.
edge://settings/privacy/sitePermissions/allPermissions/notifications
Look below where it says Allowed to send notifications and you should see an entry that ends with comultrus.co.in
Click on the three dots to the right of the entry and either Remove or Block it.
Repeat for any other entries that you didn't intentionally set.
1 additional answer
    2026-08-29T22:18:24.9466667+00:00
    Those alerts are typically fake browser notifications or pop-ups, not proof that Norton or McAfee is installed or that the PC is infected.
    Try this in order:
    1. Close the stuck Edge window if needed
      • Right-click Start > Task Manager.
      • Select Processes.
      • Under Apps, right-click Microsoft Edge > End task.
      • Reopen Edge normally.
    2. Remove the site’s notification permission in Edge
      • In Edge, open Settings and more > Settings > Privacy, search, and services > Site permissions > All sites.
      • Select the suspicious site.
      • Find Notifications and change it to Block.
      • Repeat for any other unknown sites.
    3. Turn off suspicious extensions
      • In Edge, open Settings and more > Extensions > Manage extensions.
      • Turn off all installed extensions temporarily.
      • If the pop-ups stop, re-enable extensions one at a time to find the cause.
    4. Make sure Edge is updated
      • In Edge, open Settings > About Microsoft Edge.
      • Let any update install, then restart Edge if prompted.
    5. Scan for malware
      • Open Start > Settings > Update & Security > Windows Security > Virus & threat protection.
      • Run a scan.
      • If the alerts keep returning after restart, use Scan options > Windows Defender Offline scan > Scan now.
      • Note: the offline scan restarts the PC, so save work first.
    6. Remove suspicious apps if symptoms started recently
      • Open Start > Settings > Apps > Apps & features.
      • Sort by install date and uninstall recent apps that were not intentionally installed.
    If the messages appear in the lower-right corner even when Edge is closed, that strongly indicates website notifications were allowed for a malicious site. Blocking that site in Edge notifications is the key fix.
    If the pop-ups are constant and Edge becomes unresponsive, use Task Manager first, then remove the notification permission and extensions before browsing again.
