A Microsoft file hosting and synchronization service.
On a Mac, the OneDrive icon should appear in the top menu bar. If it is missing, OneDrive is usually not running.
Try these steps:
- Use Spotlight to search for OneDrive and open it.
- If OneDrive opens, sign in if prompted and complete setup.
- If the icon still does not appear, go to Applications > OneDrive.
- Right-click OneDrive and select Show Package Contents.
- Open Contents > Resources.
- Double-click ResetOneDriveApp.command. If using the standalone app, use ResetOneDriveAppStandalone.command.
- Start OneDrive again and finish the setup process.
If the icon appears but looks faded or greyed out, that means OneDrive is not signed in or setup has not completed. In that case, start OneDrive from Finder or Spotlight and sign in again.
If OneDrive prompts that a folder already exists when signing in again, select Use this folder.
To avoid app-version issues on Mac, make sure only one version of OneDrive is installed. Running both the standalone and App Store versions side by side is not supported.
Also make sure the app is up to date by installing the latest OneDrive app for Mac.
