Problem using phone link
William Bochman 0 Reputation points
2026-08-27T14:03:06.43+00:00
Unable to use phone link. laptop does not recognize my account
Windows for home | Windows 11 | Connect Phone and PC
  1. SD - IA 178.7K Reputation points Independent Advisor
    2026-08-27T14:41:48.1966667+00:00
    Is your Microsoft account not recognized? Are you able to login using your user account in Windows?
    Have you tried signing in using your phone number?
    Microsoft account sign-in helper
    https://support.microsoft.com/en-us/accounts-billing/manage/microsoft-account-sign-in-helper
    My username and password have stopped working
    https://support.microsoft.com/en-us/accounts-billing/manage/my-username-and-password-have-stopped-working
    I look forward to hearing from you to get the results of the troubleshooting.
  2. AI answer
    2026-08-27T14:03:28.94+00:00
    Try this in order:
    1. Verify the same Microsoft account is signed in on both devices.
      • On the PC, open a browser and go to https://account.microsoft.com/devices/android-ios, then check whether the Android device appears under the account.
      • On the Android device, open Settings > Accounts if using the downloaded Link to Windows app.
      • On some Android devices, go to Settings > Advanced features > Link to Windows and check the address shown under Microsoft account.
    2. Check basic connection requirements.
      • Make sure the PC and Android device are both turned on, nearby, and connected to the same Wi‑Fi network.
      • Confirm Battery saver is off on both devices.
      • On Android, make sure Do not disturb is off.
    3. Allow Link to Windows to run without battery optimization on Android.
      • Go to Android Settings > Apps & notifications > App info > Link to Windows > Advanced > Battery > Manage Battery Usage > Battery optimization.
      • Find Link to Windows and select Don't optimize.
      • On some devices: Android Settings > Apps > Link to Windows > Battery > Optimize battery usage > All > Link to Windows > Off.
    4. Make sure Phone Link can run in the background on the PC.
      • Open Start > Settings > Privacy > Background apps.
      • Ensure Phone Link is enabled.
    5. Check Windows shared experiences.
      • Open Start > Settings > System > Shared experiences.
      • If Fix now appears under Accounts, select it and complete the prompts.
    6. If the account still is not recognized, unlink and pair again.
      • On Android: open Link to Windows > tap the Microsoft account under Linked Account > Account Settings > Sign out and unlink account > confirm Unlink.
      • On PC: open Phone Link > Settings > Devices > Add new device and complete pairing again.
    7. If prompted to reconnect with a QR code, update both apps first.
      • On Android: Link to Windows > Settings > About Link to Windows > Check for updates.
      • On PC: Phone Link > Settings > General > down arrow after Phone Link version > Check for updates.
      • Then scan the QR code shown in Phone Link with the phone camera and complete sign-in.
    8. If this started suddenly and the app accepts the account or PIN but does nothing after Continue, avoid repeated reinstall/reset attempts. That behavior has been reported as a broader service/authentication issue. In that case, send feedback through Phone Link > Settings > Feedback & Community > Send feedback or use Feedback Hub.
