Search function in Outlook classic does not work at all.
Michael Balston 0 Reputation points
2026-08-27T10:26:54.3333333+00:00
    2026-08-27T10:27:12.49+00:00
    For classic Outlook search that returns no results at all, work through these checks in order:
    1. Verify Outlook is still indexing.
      • In classic Outlook, click in the Search box.
      • Select Search Tools > Indexing Status.
      • If items are still being indexed, wait a few minutes and check again. If the count is not decreasing, continue.
    2. Make sure all Outlook data files are selected for search.
      • Select Search Tools > Locations to Search.
      • Confirm all listed data files/stores are selected.
    3. Check that the Windows Search service is running.
      • Open the Windows Start menu, search for services.msc, and press Enter.
      • Open Windows Search.
      • Set Startup type to Automatic (Delayed Start).
      • If Service status is not Running, select Start.
    4. Run the Windows Search troubleshooter.
      • Windows 11: Start > Settings > Privacy & Security > Troubleshoot > Searching Windows > Indexer troubleshooter.
      • Windows 10: Start > Settings > Update & Security > Troubleshoot > Search and Indexing > Run the troubleshooter.
    5. Confirm Outlook is included in Windows indexing.
      • Exit classic Outlook.
      • Open Indexing Options in Control Panel.
      • Make sure Microsoft Outlook appears in Included Locations.
      • If not, select Modify and enable Microsoft Outlook.
    6. Confirm the Outlook MSG filter is configured.
      • Open Indexing Options > Advanced > File Types.
      • Select msg.
      • Make sure Index Properties and File Contents is enabled.
      • The Filter Description should show Office Outlook MSG IFilter.
      • If that filter is missing, Microsoft Support is recommended.
    7. Rebuild the search catalog.
      • Open Indexing Options > Advanced.
      • Select Rebuild.
      • After rebuilding, reopen Outlook and allow indexing to finish.
    8. Test with a new Outlook profile.
      • In Outlook, go to File > Account Settings > Manage Profiles.
      • Or exit Outlook and open Mail in Control Panel.
      • Select Show Profiles > Add.
      • Create the profile, complete account setup, then set Outlook to Prompt for a profile to be used.
      • Restart Outlook, choose the new profile, and test search.
    9. Repair Office if search still fails.
      • In Windows 11, right-click Start > Installed apps.
      • In Windows 10, right-click Start > Apps and Features.
      • Select the Microsoft Office product > Modify.
      • For Click-to-Run installs, use Online Repair. This is more thorough than Quick Repair.
    If search still does not work after these steps, contact Microsoft Support.
