how to fix the problem
UPRSA UPRSA 0 Reputation points
2026-08-27T06:36:19.56+00:00
Technical details
MessageDeliveryFailedException: Could not deliver the message [len=70,
Failure code: ad29
  1. Alvise Cervellati 6,535 Reputation points Independent Advisor
    2026-08-27T07:33:10.68+00:00
    Hi @UPRSA UPRSA , Welcome in Community
    This error typically occurs in Microsoft Outlook (such as the New Outlook for Windows or Outlook client) when an outgoing email gets stuck in your Outbox or Drafts and fails to transmit via your mail server.
    Can you try via webmail if you can send successfully the email?
    Then, go offline (turn off your Wi-Fi or select Work Offline in Outlook), open your Outbox, and either delete the stuck message or move it to your Drafts. Then, go back online and try sending a fresh, simple test email.
    See if in this way the email can be sent normally
    Let me know how it goes
    Elvis
