battery charging
rahul kukana 20 Reputation points
2026-08-26T13:31:37.3966667+00:00
My laptop battery, click is on and its connected with laptop , but is not increasing the percentage of a battery
how can I solve this problem.
I am still using Windows 10 and I cannot updates or convert into a window 11.
Windows for home | Windows 10 | Sleep and Power on, off
Pavle Peković 6,850 Reputation points Volunteer Moderator
2026-08-26T13:41:03.5+00:00
How old is your laptop/battery?
Go to powershell and type:
powercfg /batteryreport
battery-report.html will be created. Open it. Compare the Full Charge Capacity to the Design Capacity.
1 additional answer
  1. rahul kukana 20 Reputation points
    2026-08-26T13:41:38.3066667+00:00
    I need one more help about about my update, I'm still using window 10 , but I want to update into window 11.
    So, how I can update my PC or laptop ?
