Hi Patrick Smallze,
Have you had a chance to try the suggestions provided in the AI Answer yet? If so, could you let me know which step you reached and what happened afterward?
If possible, please also share:
- A photo or screenshot of the exact recovery screen you're seeing.
- Your Surface model.
- The Windows version that was previously installed (if you know it). You can share the winver version if you have it recorded, although I understand you may not be able to access Windows at the moment.
In addition to the steps already suggested, if you can access Troubleshoot > Advanced options, you may also check whether System Restore, Uninstall Updates or Startup Settings (Safe Mode) are available and let me know the results.
Also, was the Surface working normally before this occurred or did the issue begin after a Windows update, reset attempt or unexpected shutdown?
If you can provide a screenshot of the current screen and the results of the above suggestions, I'll be happy to help narrow down the next steps.
If you have extra questions about this answer, please click "Comment".
