Log Name: System
Source: Microsoft-Windows-WER-SystemErrorReporting
Date: 8/25/2026 10:53:10 PM
Event ID: 1001
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Computer: DESKTOP-02GDBAM
Description:
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000093 (0x0000000000002900, 0x0000000000000000, 0x0000000000000000, 0x0000000000000000). A dump was saved in: C:\WINDOWS\Minidumps\082526-19296-01.dmp. Report Id: bf8b87f2-8d62-4aad-99e8-1cdc1d58bffe.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{abce23e7-de45-4366-8631-84fa6c525952}" />
<EventID>1001</EventID>
<Version>1</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2026-08-26T02:53:10.9746332Z" />
<EventRecordID>115745</EventRecordID>
<Correlation />
<Execution ProcessID="1524" ThreadID="1528" />
<Channel>System</Channel>
<Computer>DESKTOP-02GDBAM</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="param1">0x00000093 (0x0000000000002900, 0x0000000000000000, 0x0000000000000000, 0x0000000000000000)</Data>
<Data Name="param2">C:\WINDOWS\Minidumps\082526-19296-01.dmp</Data>
<Data Name="param3">bf8b87f2-8d62-4aad-99e8-1cdc1d58bffe</Data>
</EventData>
</Event>
Log file open, 12/28/24 17:49:58, C:/Users/billy/AppData/Local/CrashReportClient/Saved/Logs/2024.12.28_17.49.58-21896.log
LogNEPPak: Display: [NEPPak] StartupModule!
LogPakFile: lite patch auto mount pak path1 C:/Users/billy/AppData/Local/CrashReportClient/Saved/PersistentDownloadDir/lite_patch_1442700/Paks/
LogPakFile: lite patch auto mount pak path2 C:/Users/billy/AppData/Local/CrashReportClient/Saved/lite_patch_1442700/Paks/
LogPakFile: Initializing PakPlatformFile
LogPakFile: Display: Found Pak file ../../../Engine/Programs/CrashReportClient/Content/Paks/CrashReportClient.pak attempting to mount.
LogPakFile: Display: Mounting pak file ../../../Engine/Programs/CrashReportClient/Content/Paks/CrashReportClient.pak.
LogPakFile: Display: Mounted Pak file '../../../Engine/Programs/CrashReportClient/Content/Paks/CrashReportClient.pak', mount point: '../../../Engine/'
LogPakFile: Display: Mount point: '../../../Engine/' is not mounted to a valid Root Path yet, assets in this pak file may not be accessible until a corresponding UFS Mount Point is added through FPackageName::RegisterMountPoint.
LogICUInternationalization: ICU TimeZone Detection - Raw Offset: -5:00, Platform Override: ''
LogInit: ExecutableName: CrashReportClient.exe
LogInit: Build: 1.1.1442700.1442700
LogInit: Engine Version: 5.3.2-1442700+++depot_marvel+S0_release
LogInit: Compatible Engine Version: 5.3.2-1442375+++depot_marvel+S0_release
LogInit: Net CL: 1
LogInit: OS: Windows 10 (22H2) [10.0.19045.5247] (), CPU: AMD Ryzen 9 7900X 12-Core Processor , GPU: AMD Radeon RX 7900 XTX
LogInit: Compiled (64-bit): Dec 14 2024 02:40:37
LogInit: Architecture: x64
LogInit: Compiled with Visual C++: 19.40.33817.00
LogInit: Build Configuration: Shipping
LogInit: Branch Name: ++depot_marvel+S0_release
LogInit: Command Line: "C:\SteamLibrary\steamapps\common\MarvelRivals\MarvelGame\Engine\Binaries\Win64\CrashReportClient.exe" "../../../Engine/Binaries/Win64/CrashReportClient.exe" -READ=976 -WRITE=1004 -MONITOR=25072 -ProcessGroupId=9745218A493B2C18A64AC9B418F14B95 -RespawnedInstance
LogInit: Base Directory: C:/SteamLibrary/steamapps/common/MarvelRivals/MarvelGame/Engine/Binaries/Win64/
LogInit: Allocator: Mimalloc
LogInit: Installed Engine Build: 1
LogInit: Root Directory: C:/SteamLibrary/steamapps/common/MarvelRivals/MarvelGame/
LogInit: Engine Directory: ../../../Engine/
LogInit: Project Directory: ../../../Engine/Programs/CrashReportClient/
LogInit: Project Content Directory: ../../../Engine/Programs/CrashReportClient/Content/
LogInit: Relative Documents Directory: ../../../Engine/Programs/CrashReportClient/Documents/
LogInit: This binary is optimized with LTO: no, PGO: no, instrumented for PGO data collection: no
LogInit: Presizing for max 100000 objects, including 0 objects not considered by GC, pre-allocating 0 bytes for permanent pool.
LogInit: Object subsystem initialized
[2024.12.28-22.49.58:600][ 0]LogConfig: Applying CVar settings from Section [ConsoleVariables] File [Engine]
[2024.12.28-22.49.58:600][ 0]LogInit: Computer: DESKTOP-02GDBAM
[2024.12.28-22.49.58:605][ 0]LogInit: User: billy
[2024.12.28-22.49.58:605][ 0]LogInit: CPU Page size=4096, Cores=12
[2024.12.28-22.49.58:605][ 0]LogInit: High frequency timer resolution =10.000000 MHz
[2024.12.28-22.49.58:605][ 0]LogMemory: Memory total: Physical=63.1GB (64GB approx)
[2024.12.28-22.49.58:605][ 0]LogMemory: Platform Memory Stats for WindowsEditor
[2024.12.28-22.49.58:605][ 0]LogMemory: Process Physical Memory: 63.33 MB used, 63.34 MB peak
[2024.12.28-22.49.58:605][ 0]LogMemory: Process Virtual Memory: 87.04 MB used, 87.04 MB peak
[2024.12.28-22.49.58:605][ 0]LogMemory: Physical Memory: 46937.56 MB used, 17722.61 MB free, 64660.18 MB total
[2024.12.28-22.49.58:605][ 0]LogMemory: Virtual Memory: 102574.73 MB used, 64372.62 MB free, 166947.34 MB total
[2024.12.28-22.49.58:613][ 0]LogUObjectArray: 443 objects as part of root set at end of initial load.
[2024.12.28-22.49.58:613][ 0]LogUObjectAllocator: 96120 out of 0 bytes used by permanent object pool.
[2024.12.28-22.49.58:613][ 0]LogUObjectArray: CloseDisregardForGC: 0/0 objects in disregard for GC pool
[2024.12.28-22.49.58:614][ 0]LogPaths: Warning: No paths for game localization data were specifed in the game configuration.
[2024.12.28-22.49.58:614][ 0]LogInit: Using OS detected language (en-US).
[2024.12.28-22.49.58:614][ 0]LogInit: Using OS detected locale (en-US).
[2024.12.28-22.49.58:614][ 0]LogInit: Warning: No paths for engine localization data were specifed in the engine configuration.
[2024.12.28-22.49.58:614][ 0]LogTextLocalizationManager: No localization for 'en-US' exists, so 'en' will be used for the language.
[2024.12.28-22.49.58:614][ 0]LogTextLocalizationManager: No localization for 'en-US' exists, so 'en' will be used for the locale.
[2024.12.28-22.49.58:614][ 0]LogPackageLocalizationCache: current culture: en
[2024.12.28-22.49.58:614][ 0]LogPackageLocalizationCache: PrioritizedCultureNames:
[2024.12.28-22.49.58:614][ 0]LogPackageLocalizationCache: en
[2024.12.28-22.49.58:614][ 0]LogPackageLocalizationCache: Processed 2 localized package path(s) for 1 prioritized culture(s) in 0.000401 seconds
[2024.12.28-22.49.58:614][ 0]LogPackageLocalizationCache: SourcePackagesToLocalizedPackages length: 0
[2024.12.28-22.49.58:615][ 0]CrashReportCoreLog: CrashReportClientVersion=1.0
[2024.12.28-22.49.58:615][ 0]CrashReportCoreLog: CrashReportReceiver disabled
[2024.12.28-22.49.58:615][ 0]CrashReportCoreLog: DataRouterUrl: https://x20na.appdump.nie.easebar.com/unreal/upload/a29348bcb4ad1e1f0809bed7927002f7
[2024.12.28-22.49.58:615][ 0]LogCrashDebugHelper: DepotName: //depot_marvel/S0_release
[2024.12.28-22.49.58:615][ 0]LogCrashDebugHelper: BuiltFromCL: 1442700
[2024.12.28-22.49.58:615][ 0]LogCrashDebugHelper: EngineVersion: 5.3.2-1442700+++depot_marvel+S0_release
[2024.12.28-22.49.58:615][ 0]LogCrashDebugHelper: BuildVersion: 1.1.1442700.1442700
[2024.12.28-22.49.58:636][ 0]LogCrashReportClientDiagnostics: CRC/Monitoring
[2024.12.29-01.11.32:652][ 0]LogCrashReportClientDiagnostics: App/Death
[2024.12.29-01.11.32:652][ 0]LogCrashReportClientDiagnostics: App/ExitCode:0
[2024.12.29-01.11.32:748][ 0]LogCrashReportClientDiagnostics: CRC/Shutdown:2024.12.29-01.11.32:8494.1s
[2024.12.29-01.11.32:758][ 0]LogCore: Engine exit requested (reason: CrashReportClientApp RequestExit)
[2024.12.29-01.11.32:758][ 0]LogExit: Preparing to exit.
[2024.12.29-01.11.32:759][ 0]LogExit: Object subsystem successfully closed.
[2024.12.29-01.11.32:761][ 0]LogPakFile: Destroying PakPlatformFile
[2024.12.29-01.11.32:762][ 0]LogModuleManager: Shutting down and abandoning all modules.
[2024.12.29-01.11.32:768][ 0]LogExit: Exiting.
[2024.12.29-01.11.32:777][ 0]Log file closed, 12/28/24 20:11:32
