How to fix Bluetooth problem.
Ahmed Mahmoud Ali Mahmoud 20 Reputation points
2026-08-25T22:57:10.7433333+00:00
I tried to pair my laptop device with my I Phone but it fails whatever I tried
Windows for home | Windows 11 | Connect Phone and PC
  1. Ferdinand Nanalig 32,705 Reputation points Independent Advisor
    2026-08-25T23:39:00.38+00:00
    Hi! Let me help you.
    Can you please check if other devices connect to your laptop's Bluetooth?
  2. AI answer
    2026-08-25T22:57:29.03+00:00
    For a Windows 11 laptop that fails to pair with an iPhone, use this order:
    1. Confirm Bluetooth is on in Windows 11
      • Go to Start > Settings > Bluetooth & devices.
      • Make sure Bluetooth is turned on.
      • Windows should show the PC as discoverable.
    2. Check the basics on both devices
      • Make sure the iPhone is turned on and nearby.
      • Turn Bluetooth off on the iPhone, wait a few seconds, then turn it back on.
      • Keep the iPhone away from USB 3.0 devices connected to the laptop, because unshielded USB devices can interfere with Bluetooth.
    3. Make sure the laptop is discoverable
      • Go to Start > Settings > Bluetooth & devices > Devices.
      • Under Device settings > Bluetooth devices discovery, set it to Advanced.
    4. Make sure airplane mode is off
      • Select the Network, Sound, or Battery icons on the taskbar.
      • Verify Airplane mode is off.
    5. Remove the old pairing and pair again
      • On the laptop: Start > Settings > Bluetooth & devices > Devices.
      • Find the iPhone, select More options > Remove device > Yes.
      • Then try pairing again.
    6. Run the Bluetooth troubleshooter
      • Run the automated Bluetooth troubleshooter in the Get Help app.
      • It runs diagnostics and attempts to fix common Bluetooth problems.
    7. If pairing still fails, reinstall the Bluetooth adapter
      • Open Device Manager.
      • Expand Bluetooth.
      • Right-click the Bluetooth adapter and select Uninstall device.
      • Shut down the laptop, wait a few seconds, then turn it back on so Windows can reinstall the driver automatically.
      • If Windows does not reinstall it, open Device Manager and use Action > Scan for hardware changes.
    8. If using Phone Link with iPhone
      • Remove the iPhone from Phone Link > Settings > My Devices if it appears there.
      • Remove the iPhone from Windows Bluetooth settings.
      • On the iPhone, forget the PC in Bluetooth settings.
      • Turn Bluetooth off on both devices, wait about 10 seconds, then turn it back on.
      • Start the setup from Phone Link on the PC and follow the guided pairing steps.
    If a PIN is requested during pairing and none is shown, common fallback PINs mentioned for Bluetooth accessories are 0000 or 1234.
  3. Kapil Arya 38,266 Reputation points Volunteer Moderator
    2026-08-26T10:39:54.28+00:00
    Try restarting both devices, then retry reconnecting.
  4. michael dixon 0 Reputation points
    2026-08-28T11:10:45.1366667+00:00
    I have connected my majority snowdon to bluetooth, it says its connected but no sound coming throw
