How to restore my Explore Background
Veronica Bunas 0 Reputation points
2026-08-25T16:23:50.66+00:00
How to restore my Explore Background. This is a standard feature that no longer is showing. Next Background remains.
[Tag moved from: Microsoft 365 and Office | Other]
Windows for home | Windows 11 | Desktop, Start, and personalization | Desktop
  1. Norah-L 10,490 Reputation points Microsoft External Staff Moderator
    2026-08-26T01:19:28.43+00:00
    Hello Veronica Bunas,
    It sounds like the Explore background option is missing when you right-click the desktop, although Next background is still available. This option is part of Windows Spotlight and may appear under the newer name Learn more about this background.
    Please try the options below and check whether the issue continues:
    I recommend trying the following:
    1. Open Settings > Personalization > Background.
    2. Temporarily change Windows spotlight to Picture, then change it back to Windows spotlight.
    3. Press Ctrl + Shift + Esc to open Task Manager. Under Processes, right-click Windows Explorer and select Restart.
    4. Right-click an empty area of the desktop again and check whether Explore background or Learn more about this background has reappeared.
    5. Open Settings > Windows Update, install any available updates, and restart the computer.
    If it is still missing, please press Windows key + R, enter winver, and share the Windows version and OS build shown. The exact menu options can vary by Windows build, so this information will help narrow down the next step.
    Please let me know how it goes after trying these steps, and I'll be glad to continue looking into it with you.
    If the answer is helpful, please click "Yes" to accept answer and kindly upvote it. If you have extra questions about this answer, please click "Comment".
