Shift Key not working
loan 20 Reputation points
2026-08-25T07:42:07.76+00:00
Shift Key not working pz slove this prooblem manetimes
Windows for home | Windows 11 | Input and language
AI answer
2026-08-25T07:42:31.1866667+00:00
Try these steps in order:
  1. Test the On-Screen Keyboard
    • Press Windows + R, type OSK, and press Enter.
    • Check whether Shift works there.
    • If Shift works on the On-Screen Keyboard, the physical keyboard is more likely the problem.
  2. Reinstall the keyboard driver
    • Press Windows + X and open Device Manager.
    • Expand Keyboards.
    • Right-click the keyboard device and select Uninstall device.
    • Restart the PC.
    • Windows should reinstall the keyboard driver automatically after restart.
  3. Run the keyboard troubleshooter command
    • Open Command Prompt.
    • Run:
           msdt.exe -id KeyboardDiagnostic
    • Complete the troubleshooter and check whether Shift starts working.
  4. Check whether it is hardware or software
    • If available, connect another external keyboard and test the Shift key.
    • If the external keyboard works but the laptop keyboard does not, the built-in keyboard is likely faulty.
If both left and right Shift keys are not working, the issue is commonly either a keyboard driver problem or a hardware keyboard problem.
1 additional answer
  1. loan 20 Reputation points
    2026-08-25T07:48:35.6933333+00:00
    Thankyou so much.
