lucen timeline swimlane formatting issues
Vivek Gade 0 Reputation points
2026-08-24T14:16:05.5666667+00:00
  1. lucen timeline swimlane formatting changes and extends outside the ppt slide boundaries. How to freeze that when switching to edit mode.
  2. Also how to do fit to page instead of manually shifting and reducing boxes and milestones when we have multiple swim lanes.
  3. Expectation is that Lucen timeline should auto format and accomodate all the swim lanes on one side instead of them getting beyond the allocated white spce on the ppt slide.
  4. This has been very frustrating and time consuming for me. Please help
Microsoft 365 and Office | PowerPoint | For business | Windows
  1. Ruby Nguyen 1,565 Reputation points Independent Advisor
    2026-08-24T15:17:07.2566667+00:00
    Good day Vivek
    Based on Microsoft documentation, PowerPoint uses a fixed slide size and does not include a feature that automatically resizes all content when it extends beyond the slide. The Ensure Fit option is only available when the slide size or orientation is changed.
    Since Lucen Timeline is a third-party PowerPoint add-in, PowerPoint doesn't provide a setting to control how the timeline is resized or rearranged when you open Edit mode.
    Here are a few options you can try:
    Option 1: Use Ensure Fit after changing the slide size
    This is the closest built in PowerPoint option to a Fit to Page feature.
    Save a copy of the presentation.
    Go to Design > Slide Size > Custom Slide Size.
    Review or adjust the slide dimensions and select OK.
    When prompted, choose Ensure Fit.
    This scales the existing content to fit within the selected slide size. The adjustment applies when the slide size is changed and is not maintained automatically afterward.
    Option 2: Group and lock the finished timeline
    After completing all timeline edits:
    Open Home > Arrange > Selection Pane.
    Select the timeline objects and group them (Ctrl + G) if available.
    Use the lock option in the Selection Pane to prevent unintended changes.
    This helps keep PowerPoint objects in place. However, PowerPoint doesn't provide a setting that controls how a third party add-in rebuilds or refreshes its content in Edit mode.
    Option 3: Contact the Lucen support team
    If the timeline only changes size in Edit mode, the Lucen add-in controls its behavior.
    You may consider contacting the Lucen support team using the following link: Contact Lucen
    Note: This link is shared by community members for your convenience. It points to a third-party site that is not managed or verified by Microsoft. I can’t guarantee the quality, safety, or suitability of any content or software found there. Please review carefully and make sure you understand any potential risks before using it.
    When contacting Lucen support, please provide a sample presentation, before/after screenshots, the number of swimlanes and sub-swimlanes, your PowerPoint and Lucen Timeline versions and the current slide size and orientation.
    Additional information is available in the following resources:
    Change the page layout | Microsoft Support
    Change the size of your PowerPoint slides | Microsoft Support
    I hope this information is helpful. If you have any questions or need further support, please don’t hesitate to reach out at any time.
    Thank you for your patience and understanding.
    If the answer is helpful, please click "Yes" and kindly upvote it. If you have any extra questions about this answer, please click "Comment".
    Note: Please follow the steps in the forum documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
