How to reset Surface to factory settings
Javier Balderrama 0 Reputation points
2026-08-24T12:12:28.7966667+00:00
We got a SurfacePro Model 1796 from a business that closed and all computer assets were given away, a former employee is logged in this particular computer and I need to reset it to Factory settings. I am able to get to the point within the "Windows Recovery Environment" where it asks:
"Enter the recovery key to get going again ( Keyboard Layout:US)"
it provides me with the Recovery Key ID( to identify your key) but we do not have access to the business accounts. We do not have access to the former employee.
How can I reset it?
Javier
Windows for business | Windows Client for IT Pros | Devices and deployment | Recovery key
    2026-08-24T12:12:49.15+00:00
    If the device is stopping at the BitLocker recovery key screen and the recovery key is not available, the supported reset path is to use a Surface USB recovery drive to reinstall Windows.
    Important: this process deletes all personal files, resets settings, and removes installed apps.
    Steps:
    1. On another working Windows PC, download the correct factory recovery image for that Surface from the Surface Recovery Image Download page.
    2. Create a USB recovery drive for the Surface.
    3. On the Surface, make sure it is turned off and plugged in.
    4. Insert the USB recovery drive into the USB port.
    5. Press and hold the volume-down button, then press and release the power button.
    6. When the Microsoft or Surface logo appears, release the volume-down button.
    7. When prompted, select the language and keyboard layout.
    8. Select Recover from a drive or Troubleshoot > Recover from a drive.
    9. If prompted for a recovery key, select Skip this drive at the bottom of the screen.
    10. Choose:
    • Just remove my files if the device will be kept
    • Fully clean the drive if the device will be recycled or transferred; this is more secure but takes much longer
    1. Select Recover.
    If the built-in Windows reset feature is failing, Microsoft recommends trying Windows Update first if possible, or using a Surface USB recovery drive instead.
    If Windows still does not start after using the USB recovery drive, the next step is service or repair support.
  2. Harry Phan 30,640 Reputation points Independent Advisor
    2026-08-24T14:14:07.51+00:00
    Hello Javier,
    The message you’re seeing is a BitLocker recovery prompt. That means the Surface Pro has BitLocker enabled, and Windows cannot continue until the recovery key is provided. The recovery key is tied to the Microsoft account or Azure AD account that originally set up the device. Since you don’t have access to the business accounts or the former employee’s credentials, there is no way to retrieve that recovery key. Microsoft does not provide a bypass method for BitLocker — this is by design to protect the data on the drive.
    The only way forward is to completely wipe the device and reinstall Windows from scratch. On a Surface Pro 1796, you can do this by creating a bootable USB with the latest Windows 11 installation media. Download the Media Creation Tool from Microsoft on another PC, use it to create a bootable USB, then insert it into the Surface. Power off the Surface, hold the Volume Down button, and press Power to boot from USB. From there, delete all partitions during setup and perform a clean installation. This will remove the BitLocker protection and reset the device to factory state.
    If you prefer the official Surface recovery image, you can go to Microsoft’s Surface Recovery Image download page, enter the device’s serial number (found on the kickstand), and download the correct image. Use that to create a recovery USB, boot from it, and perform the reset. That will restore the Surface to its original factory configuration.
    Without the recovery key, you cannot unlock the existing installation, so the only viable solution is a clean reinstall. Once complete, the device will be yours to set up with a new account.
    I hope you've found something useful here. If it helps you get more insight into the issue, it's appreciated to accept the answer. Should you have more questions, feel free to leave a message. Have a nice day!
    HP.
