Disk Storage: Dependency Issue Preventing Resource Deletion — Managed Disk No Longer Visible in Portal
Josh Haley 0 Reputation points
2026-08-24T03:14:53.37+00:00
Problem description
I am unable to delete all resources related to my Azure environment because a managed disk that was previously attached to a virtual machine still appears to be in use, even though it has since been deleted and shows a 404 error when attempting to access. Attempts to remove the disk and associated resources fail with errors indicating a dependency or resource in use.
All resources except for this disk, its restore point collection, and that collection's resource group have been successfully deleted.
Environment
Azure Disk Storage in Australia East region, involving a managed disk, backup restore points in a Recovery Services vault, and related VM resources.
What I've already tried
I have tried deleting the resource directly, via the portal and powershell. I have checked for soft-delete and SAS permissions. I have attempted to force-delete the disk but as there is no disk to delete it has been unsuccessful.
Current status
I am seeking assistance to identify the lingering dependency preventing resource deletion and to perform a force delete of all related resources to free my account and continue my studies.
Azure Disk Storage
Azure Disk Storage
A high-performance, durable block storage designed to be used with Azure Virtual Machines and Azure VMware Solution.
  1. Andriy Bilous 12,191 Reputation points MVP
    2026-08-28T06:34:32.6666667+00:00
    Hello Josh Haley
    This looks much more like an orphaned Restore Point Collection / Disk Restore Point dependency than a managed-disk problem.
    The fact that the original managed disk now returns 404 is expected after deletion. Trying to force-delete that disk will not help because the resource Azure is refusing to remove is probably a child restore-point object that still contains a reference to the deleted disk.
    The remaining restore-point objects can still reference it and block deletion.
    Try:
    az resource list \   --resource-type Microsoft.Compute/restorePointCollections \   -o table
    Then delete the collection:
    az restore-point collection delete \   --resource-group <RG> \   --collection-name <collection-name> \   --yes
    If deletion fails, check for:
    • nested Disk Restore Points
    • an active SAS on a Disk Restore Point
    • resource locks
    • a remaining/soft-deleted VM backup item in the Recovery Services vault
    Also check the Activity Log for the failed DELETE operation the exact error.code and error.message should identify the remaining dependency.
    If the collection cannot be deleted even after all dependencies are gone, it may be orphaned Azure backend metadata and require an Azure Support cleanup.
