How to fix grainy and dark camera/video quality on Lenovo Yoga 7i
Kirstina Hicks 0 Reputation points
2026-08-23T15:49:52.15+00:00
I've done everything, it seems. I've updated the driver, changed the settings in the camera, reset the settings, changed the refresh rate, adjusted the camera settings. Nothing works!! My camera quality is HORRIBLE. It's dark and grainy. I've even tried it in different lighted environments. Please help!!
Windows for home | Other | Music, photos, and video
    2026-08-23T15:51:04.71+00:00
    For a Lenovo Yoga 7i with a camera that stays dark and grainy after driver updates, resets, and Camera app changes, the supported next checks are:
    1. In the Camera app, open Settings from the top-left and review:
      • Video settings → adjust video quality and flicker reduction.
      • Photo settings → check photo quality.
      • Camera settings → switch between using Camera app settings and the system Camera settings.
    2. Open the Windows camera settings page and select the built-in camera from Connected cameras.
      • Check Basic settings if they appear.
      • If available, use Reset settings to return the camera to factory defaults. This clears changes to basic settings, effects, and video rotation.
      • Use Troubleshoot on that same camera page to launch Get Help for the interactive camera troubleshooter.
    3. If the image is still poor, verify lighting and anti-flicker behavior.
      • Poor lighting can make webcam video look dark, blurred, or pixelated.
      • A wrong anti-flicker setting for local power frequency can also reduce quality.
      • In the Camera app, adjust flicker reduction under Video settings.
    4. If the camera remains extremely fuzzy after resets and lighting checks, treat it as a likely hardware issue.
      • A Microsoft Q&A resolution for a new Lenovo system recommends running Lenovo Vantage Hardware Scan.
      • If the scan passes, the issue is more likely a blockage or software effect.
      • If it warns, reinstalling drivers through Lenovo Vantage can help.
      • If it fails, the camera module likely needs service or replacement.
    5. If using an external webcam for comparison, the Windows camera settings page also allows Video rotation for external cameras only. Note: changing video rotation can affect app compatibility because Windows removes compressed formats such as MJPEG and H.264 when rotation is enabled.
    Given that driver updates, resets, and app setting changes were already tried, the most relevant next step is Lenovo Vantage Hardware Scan and, if that does not clear it, hardware service/warranty support for the built-in camera.
  2. DaveM121 931.9K Reputation points Independent Advisor
    2026-08-23T16:27:19.0466667+00:00
    1
    You indicate you have tried changing settings for your webcam, did you open the Settings App, then go to Bluetooth & Devices - Cameras - Integrated Camera and try adjusting the Brightness, Contrast, Sharpness and Saturation on your webcam and that did not resolve the problem?
    2
    If so, are you in a correctly lit room with the main room light behind the screen of your laptop pointing at you?
    3
    You indicate you have updated the webcam drivers, the best option would be to go to the support page for your laptop on the Lenovo website to download and reinstall (not update) the version of Chipset drivers, Webcam drivers and Graphics drivers they provide.
