Unable to create lines after a paragraph in a Microsoft 365 word document
Bob Schild 236 Reputation points
2026-08-22T09:57:30.62+00:00
These are not working:
|| || 1.     Enter three
2.     Press the ENTER key,
|| || 1.     Enter three =
|| || 1.     Enter three #
|| || 1.     Enter three ~
2.     Press the ENTER key.
TaoLi 111.1K Reputation points Independent Advisor
2026-08-22T10:49:45.38+00:00
It looks like the automatic horizontal line feature in Word is disabled. The shortcuts (---, ===, ###, ~~~) only work when Border Lines is enabled in AutoFormat settings.
Please try:
Open Word → FileOptions
Go to ProofingAutoCorrect Options
Open AutoFormat As You Type
Under Apply as you type, enable Border Lines
Click OK and restart Word
Reference: https://support.microsoft.com/en-us/office/insert-a-horizontal-line-9bf172f6-5908-4791-9bb9-2c952197b1a9
If it is already enabled, try repairing Microsoft 365:
Settings → Apps → Installed apps → Microsoft 365 → Modify → Quick Repair
After that, test again with a blank document and type:
--- + Enter
It should create the horizontal line automatically.
AI answer
2026-08-22T09:57:44.7266667+00:00
Those character shortcuts create a horizontal line only when the automatic Border Lines feature is enabled in AutoCorrect.
To turn it on in Word:
  1. Open File > Options.
  2. Select Proofing.
  3. Select AutoCorrect Options.
  4. Open the AutoFormat As You Type tab.
  5. Make sure Border Lines is checked.
  6. Select OK.
Then try again by typing three characters and pressing Enter.
If a line is created and needs formatting afterward, it is inserted as an empty paragraph with a bottom border. That can be changed from Home > Borders > Borders and Shading.
If pressing Enter behaves unexpectedly inside lists, that was a known issue in Word for Microsoft 365 and was fixed in Word builds 17619.20000 (version 2405) and later.
1 additional answer
  1. Charles Kenyon 170.7K Reputation points Volunteer Moderator
    2026-08-22T14:53:56.55+00:00
    Turn on automatic border lines in AutoFormat As You Type (not AutoFormat).
    File > Options > Proofing > AutoCorrect Options > AutoFormat As You Type (tab)
    Resources:
