Activation issue after hardware update
BrissyGTR - Chris 20 Reputation points
2026-08-22T04:11:49.3433333+00:00
My computer was not upgradable to windows 11. I replaced the motherboard, CPU, RAM and added a new system drive. This was required for the windows 11 (and future) update. My digital licence is linked to my account and the details show the OS Edition: Windows 10 Professional. OS Build: 10.0.19045.7663. After the install of Windows 10 Professional from Microsoft the computer is now listed with OS Edition: Windows Professional and the OS Build: 10.0.19045.6456. Activation does not show the old PC listing to allow for re-activation after hardware change.
It is due to the OS Edition making?
How can I fix this?
Can I go directly to Windows 11 and that will fix the issue?
Ivan B 122.5K Reputation points Independent Advisor
2026-08-22T04:49:41.8633333+00:00
In this case, when you upgraded from Windows 7 to 10, it became an OEM license because you changed the motherboard to which the license is tied. You won't be able to use that same license.
You would have to buy a new license if the Windows 7 keys are not valid to activate on Windows 10 or 11, even after upgrading via OEM license.
OEM licenses are tied to the hardware, so the license is on the old motherboard.
I'm sorry.
On the new computer, you can install Windows 11 directly if it's compatible and buy the license from the Microsoft Store or the Microsoft website.
Please consider rating the question (accept the answer or not), and access the community at Microsoft Q&A if you have further questions.
2 additional answers
    2026-08-22T04:12:04.4333333+00:00
    A motherboard replacement is a significant hardware change, so Windows may no longer match the old digital license to the device. The edition name difference shown as Windows 10 Professional versus Windows Professional is not the supported reason in the provided guidance. The supported checks are:
    1. Confirm the installed edition matches the license
      • Open Start > Settings > System > Activation.
      • Verify the edition is the same edition the license is for.
      • If the license does not match the installed edition, Windows will not activate.
    2. Run the Activation troubleshooter
      • Go to Start > Settings > System > Troubleshoot.
      • This option is available only when Windows is not activated.
      • An internet connection is required.
      • Administrative sign-in is required.
    3. If the old device does not appear in the hardware-change flow
      • The documented requirement is that the Microsoft account must be associated with the digital license to reactivate after significant hardware changes.
      • If the troubleshooter cannot fix the issue, the next supported step is to contact support.
    4. If a product key is available
      • Go to Start > Settings > System > Activation > Change product key.
      • Enter the 25-character product key and follow the prompts.
    5. Upgrading directly to Windows 11
      • Going directly to Windows 11 is not documented here as a fix for a missing old-device listing in activation.
      • Windows 11 still requires the license edition to match, and significant hardware changes can still require reactivation.
    If the device remains unactivated after running the troubleshooter, use the activation support path referenced in the activation articles.
  2. BrissyGTR - Chris 20 Reputation points
    2026-08-22T04:24:04.7233333+00:00
    My computer has been around for many years and originally was loaded with Windows 7 Professional as Windows 10 was released. The system was updated and ran Windows 10 professional.
    I have (I think) the activation code from Windows 7 Professional will that code activate the Windows 10 Professional?
