Looking for a way to monitor updates to the Microsoft Product Lifecycle data automatically
Reganti Naday Kumar 0 Reputation points
2026-08-21T04:18:08.03+00:00
Hi Team,
We are looking for a way to monitor updates to the Microsoft Product Lifecycle data automatically.
Currently, we are referring to the Microsoft Lifecycle page regularly to identify changes such as:
  • New products/components being added
  • Existing product versions being updated
  • End of Support (EOS) / End of Servicing dates being changed
  • Products moving to Extended Support
  • Products being retired or removed
Instead of manually checking the Lifecycle page every day, we would like to know if Microsoft provides any official API, data feed, RSS feed, webhook, notification mechanism, or other programmatic interface through which we can detect lifecycle data changes.
Specifically, could you please clarify:
  1. Is there an official API available to retrieve Microsoft Lifecycle data programmatically?
  2. Is there any change notification mechanism that can notify us when lifecycle data is updated?
  3. Is the Lifecycle Data Export updated whenever there is a change, and can we use it for automated monitoring?
  4. Is there an RSS/feed or similar mechanism available to track changes to the Lifecycle data?
  5. If no notification mechanism is available, what is the recommended Microsoft-supported approach for automatically detecting changes without manually visiting the Lifecycle page every day?
Our objective is to build an automated monitoring process that can periodically check Microsoft Lifecycle data and notify us whenever there is a change, particularly to EOS dates.
Thanks!
Windows for business | Windows Client for IT Pros | Devices and deployment | Other
  1. Allan Solomon Mejia 7,995 Reputation points
    2026-08-21T21:21:28.8833333+00:00
    Hello @Reganti Naday Kumar
    For this requirement, the Microsoft Lifecycle Data Export is currently the most appropriate Microsoft-published source for automation. Microsoft provides the Lifecycle product search and an export containing lifecycle information such as product, edition, release, support policy, start date, mainstream support date, extended support date, retirement date, release end date, and documentation URL.
    Regarding your specific questions:
    1. Official API: I don't see a publicly documented/supported Microsoft Lifecycle REST API for retrieving the complete Product Lifecycle dataset. I would therefore avoid depending on undocumented endpoints used internally by the Lifecycle website.
    2. Change notifications/webhooks: I also don't see Microsoft documenting a webhook or event-based notification service specifically for changes to the Lifecycle dataset.
    3. Lifecycle Data Export: Yes, Microsoft provides the official Product Export and documents the structure of the exported lifecycle data. However, I don't see a documented SLA stating that the export is regenerated immediately after every lifecycle change. I wouldn't design an automation that assumes real-time synchronization unless Microsoft confirms that behavior.
    4. RSS: I don't see an official RSS/Atom feed specifically covering every change made to the Product Lifecycle dataset. Microsoft does publish Lifecycle announcements, but that isn't equivalent to a machine-readable change feed for the entire dataset. The Lifecycle site currently surfaces announcements alongside its product lifecycle information.
    5. Recommended automation: Without a documented API/webhook, I would periodically retrieve the official Lifecycle Data Export, normalize the relevant columns, and compare it with the previous successful snapshot.
    For example:
    Screenshot 2026-08-21 162155
    I would store the previous dataset rather than only checking whether the export file itself changed. That allows you to generate useful notifications such as:
    SQL Server xxxx
    Extended Support:
    Old: 2030-01-01
    New: 2030-06-01
    or:
    Product XYZ
    New retirement date: 2027-10-01
    For products under the Modern Lifecycle Policy, I'd supplement this with the appropriate product/service announcement channels. Microsoft states that Modern Policy products can change more frequently and provides notification requirements for changes requiring customer action and for product retirement.
    For an enterprise implementation, I would use Lifecycle Data Export as the authoritative baseline, periodically compare snapshots, and supplement it with product-specific channels such as Azure Updates or Microsoft 365 roadmap/communications, where applicable.
    I would not scrape the HTML Lifecycle pages or reverse-engineer their internal APIs, since those interfaces aren't documented contracts and could change without notice.
    Sharing these references with you:
    Microsoft Lifecycle Data Export | Lifecycle Data Export guidance | Microsoft Lifecycle Policy | Modern Lifecycle Policy
    Help make this community better for everyone: if this answer resolved your issue, please accept it or leave an upvote. If not, share more details in a comment so we can continue the discussion and find the right solution.
