POWERPOINT NEEDS REPAIR
cheska cabanlit 0 Reputation points
2026-08-21T03:04:56.4433333+00:00
I was about to open a file in power point presentation, but it states that it needs to be repaired.
Microsoft 365 and Office | PowerPoint | Other | Other
    2026-08-21T03:05:11.2633333+00:00
    A PowerPoint file that needs repair is usually either blocked by Microsoft 365 for security reasons, saved in an older format, or corrupted.
    Try these steps in order:
    1. Check whether the file is blocked
      • Open File Explorer.
      • Find the presentation file.
      • Right-click it and select Properties.
      • If there is an Unblock button near the bottom right, select Unblock > Apply > OK.
      • Try opening the file again.
    2. Try another copy of the file
      • If the file came from email, ask for it to be sent again.
      • If it came from removable media, try another copy from a different disk or source.
    3. Check whether it is an old PowerPoint 95 file
      • PowerPoint 2007 and later cannot open presentations saved as PowerPoint 95 files.
      • Open the file in PowerPoint 2003, 2002, 2000, or 97.
      • Select File > Save As.
      • In Save as type, choose Presentation (*.ppt), then save it.
      • Open the newly saved file in the newer PowerPoint version.
    4. Repair Office if file opening is failing because of Office app issues
      • Open Control Panel.
      • Go to Programs > Programs and Features.
      • Select the Office product.
      • Choose Change.
      • Start with Quick Repair.
      • If needed, use Online Repair, which is more thorough.
    5. If PowerPoint itself is unstable, test without add-ins
      • Open Start.
      • Type PowerPnt /safe and run it.
      • If the file opens, go to File > Options > Add-Ins.
      • Select COM Add-ins > Go.
      • Clear the add-in check boxes, select OK, and restart PowerPoint.
    If the message specifically says “Can’t read file” or “Presentation cannot be opened”, the file may have been blocked and the Unblock step is the first thing to try.
    If the message says “PowerPoint could not open the file” or “No text converter”, that points to file corruption and repair may be required.
  2. Estrella721 45,810 Reputation points Independent Advisor
    2026-08-21T03:43:13.4966667+00:00
    What changes did you make to your computer or subscription before the issue occurred?
    I suggest running Online Repair to thoroughly fix the Office installation:
    In the search bar, type Control Panel > Programs and Features > Microsoft 365/Office > Right-click > Change > Online Repair.
    If the issue persists, open PowerPoint in Safe mode:
    Press Win + R, type powerpnt /safe, and press Enter to start Microsoft PowerPoint in Safe Mode. This loads PowerPoint with only the essential components and temporarily disables add-ins, which can help identify if an add-in is causing the issue. If PowerPoint opens correctly in Safe Mode, go to File > Options > Add-ins and disable the add-ins one by one to identify the cause.
