URGENT:Hardware Developer Program stuck at Active‑In, agreements blank, hardware dashboard access restricted
Li Yan 0 Reputation points
2026-08-20T06:34:27.5233333+00:00
Our tenant organization vetting completed with status Authorized.
Hardware developer program status shows Active‑In under Account Settings‑Programs, but still shows "Get Started" button and cannot finish enrollment workflow.
Symptoms:
  1. Account settings > Agreements page is completely blank, no hardware‑related legal agreements available to accept.
  2. Visiting hardware dashboard https://partner.microsoft.com/dashboard/hardware returns error: "Access restricted. We’re sorry, you don’t have permission to access this page because your Partner Center account has been deactivated."
  3. My‑Access page does not show Hardware developer programs workspace and any hardware‑specific roles.
  4. DigiCert EV Code‑Signing certificate uploaded successfully with status Active, subject matches publisher name exactly, valid until 2026‑09‑12.
  5. Current login account is Entra Global Administrator for this tenant.
  6. Checked inbox, junk folder and Defender quarantine mailbox, the hardware enrollment questionnaire email was NEVER delivered to this admin mailbox.
Requested actions for backend team:
  1. Re‑trigger full backend provisioning for Windows Hardware Developer Program for this tenant.
  2. Generate missing hardware‑related legal agreements so we can accept them inside Partner Center.
  3. Resend hardware enrollment questionnaire email to ******@VenustechGroupInc.onmicrosoft.com.
  4. Resolve the "account has been deactivated" access error for hardware workspace.
This is backend provisioning bug, please do not redirect me to general public FAQ.
Microsoft Partner Center | Other
    2026-08-20T06:34:47.2133333+00:00
    The supported next steps are:
    1. Verify the Partner Center organization state in Partner Center → Account settings → Legal profile and confirm all required conditions are met:
      • Vetting status is Authorized
      • Program enrollments are Active
      • All required agreements are accepted
    2. Check whether the issue is role or workspace visibility related:
      • In Partner Center → Settings → Account settings → My Access, review assigned access.
      • For Hardware developer programs, access is granted by a person in the Owner or Manager role in the organization.
      • Under Request access and help, expand the workspace contacts list to identify who can grant access.
    3. Confirm the correct sign-in identity is being used. If work and personal accounts have similar names, sign in with the organization’s work account.
    4. If the hardware workspace is still unavailable or the enrolled account cannot sign in to the Hardware Program support flow, open a support case through Partner Center support. This path is specifically for cases where enrollment is incomplete, the enrolled tenant can’t be accessed, or sign-in with an enrolled Hardware Program account isn’t possible.
      • Go to Partner Center support
      • Under Next Step, choose Provide issue details
      • Complete and submit the case
    5. If sign-in with a Hardware Program enrolled account becomes possible, use Microsoft Engage Center, which is the recommended and fastest route for Hardware Program support. When creating the case, select:
      • Product: Windows Developer Center
      • Problem Type: Hardware Device Drivers
    The documented causes that can block user management, workspace access, or actions in Partner Center are organization profile state, missing accepted agreements, inactive enrollments, missing roles, or use of the wrong sign-in account. For conditional access restrictions, resolution must come from the organization’s Entra administrator; Microsoft can’t override those policies.
