Need Help Fixing a Formula in an Excel Spreadsheet
Kiwi1 40 Reputation points
2026-08-19T20:38:23.6533333+00:00
I have a spreadsheet created, but the formula in on column is causing a problem. I need to keep track of when children in my childcare center's physical expires. My columns are:
Column A = Child's Name
Column B = Child's DOB
Column C = Health Appraisal Date
Column D = Child's Current Age
Column E = Health Appraisal Expiration Date
Column F = Status (expired, current or expiring in 30 days)
Column G = Child's Age at the time of the health Appraisal
Here's are examples of some of the rows of data starting with column B ( I excluded the child's name column (A).
The problem I am having is with Column E. It is essentially calculating right, but I need it to do it a little different. The current formula is calculating this data- Health appraisals expire every 13 months for infants - 2 1/2 year olds. Health appraisals expire every 2 years for children 2 1/2 years old - schoolage. I need the formula to calculate so that as soon as they become a preschooler (2 1/2 - schoolage) they wouldn't need their health appraisal 13 months from the last date, but instead 2 years from the last health appraisal date. If you look at the chart the one that says expired is technically not expired. The child had their last health appraisal on 3/14/25 (when they were 2 years, 3 months old), but they are over 2 1/2 and are now considered a preschooler so their health appraisal isn't technically due until 3/14/2027. The other two rows are correct, but the third row will end up being wrong if I don't get the formula corrected because they will turn 2 1/2 before their current health appraisal will expire so it wouldn't be due until 6/23/28. I hope this makes sense. A Child under 2 1/2 expires 13 months and children who reach 2 1/2 or are already over 2 1/2 expire every two years. Is there a formula that can do this? Here's the current formula that's being used in column E and column F.
Column E- Health Appraisal Expiration Date
=IF(C3="","",EDATE(C3,IF(DATEDIF(B3,C3,"M")<30,13,24)))
Column F- Status (expired, current or expiring in 30 days)
=IF(E3="","",IF(E3<TODAY(),"Expired",IF(E3<=TODAY()+30,"Expiring in 30 days","Current")))
Thank you, in advance, for your help!
Microsoft 365 and Office | Excel | Other | Other
AI answer
2026-08-19T20:38:45.4133333+00:00
Use a formula in Column E that checks both conditions:
  • if the child was already 30 months or older on the appraisal date, expire in 24 months
  • if the child was under 30 months on the appraisal date, but will reach 30 months before the 13-month expiration, then also expire in 24 months
  • otherwise expire in 13 months
In E3:
=IF(C3="","",IF(DATEDIF(B3,C3,"M")>=30,EDATE(C3,24),IF(EDATE(B3,30)<=EDATE(C3,13),EDATE(C3,24),EDATE(C3,13))))
How it works:
  • DATEDIF(B3,C3,"M")>=30 checks whether the child was already 2 years 6 months old at the time of the health appraisal.
  • EDATE(B3,30) calculates the date the child turns 30 months.
  • EDATE(C3,13) calculates the normal 13-month expiration date.
  • If the 30-month birthday is on or before that 13-month expiration date, the formula switches to 24 months from the appraisal date.
For the examples described:
  • appraisal at 2 years 3 months and now over 2 1/2: this formula returns 2 years from the appraisal date
  • child currently under 2 1/2 but turning 2 1/2 before the 13-month mark: this formula also returns 2 years from the appraisal date
  • child still under 2 1/2 through the full 13 months: this formula keeps the 13-month expiration
Column F can stay as-is:
If Column E shows a number instead of a date, format the cells as a date:
Home > Number Format > Short Date
0 additional answers
