If someone else set this laptop computer up with a PIN, then that raises a whole new question; like why was I sold a used computer as new?
Surface Laptop PID issues.
I have a new Surface Laptop, purchased December 25, I have never used this computer because it demands a PIN which I don't have. WHY?
Surface | Surface Laptop | Safety and security
S.Sengupta 32,031 Reputation points MVP Volunteer Moderator
2026-08-20T00:20:20.0366667+00:00 There are a few possibilities:
The machine was already set up before you received it — for example, it may have been opened, configured, returned, or previously assigned to someone.
Windows setup was interrupted and the device retained a partially created Windows Hello profile.
The Surface was previously associated with another Microsoft account/user.
Less commonly, Windows Hello provisioning has become corrupted.
If this was genuinely sold to you as a new Surface, I would first want to determine whether Windows is showing your Microsoft account or somebody else's account.
If you are at the Windows sign-in screen, look underneath the PIN box for:
I forgot my PIN
Microsoft specifically provides this option to reset a PIN when you cannot sign in.
Also click:
Sign-in options
and see whether you are offered the password sign-in option instead of PIN. Microsoft confirms that if PIN reset isn't available, you can use the account password and then reset the PIN from Windows.
