computer is not communicating with my printer
mike abate 0 Reputation points
2026-08-19T16:58:04.09+00:00
computer not communicating with my printer
My computer is not communicating with my printer. Therefore, I can't print. It just suddenly stopped working,
I'm wondering if I have malware on my computer? Please help
    2026-08-19T16:58:22.02+00:00
    This usually means the printer cannot communicate with the PC. Common causes in Windows are a connection problem, the printer being in an error/offline state, or a driver/spooler issue. The provided guidance does not identify malware as a cause.
    Try these steps in order:
    1. Restart the printer
      • Turn off the printer.
      • Unplug it, wait 30 seconds, plug it back in, and turn it on.
    2. Check the connection
      • USB printer: make sure the cable is firmly connected to both the printer and the PC.
      • Wi‑Fi printer: make sure the printer’s wireless option is on and that the PC is connected to the same Wi‑Fi network as the printer.
      • If the printer has a wireless connectivity test in its menu, run it.
    3. Check printer status in Windows
      • Open Settings > Bluetooth & Devices > Printers & scanners.
      • Select the printer and check whether it appears offline or in an error state.
      • If the printer status shows Stopped, add the Status Reason column to look for errors such as Out of toner or Off-line.
      • Also check for simple printer-side issues like low paper, low ink/toner, open cover, or paper jam.
    4. Run the Windows printer troubleshooter
      • Go to Settings > System > Troubleshoot > Other troubleshooters.
      • Select Run next to Printer.
      • On Windows 10, the troubleshooting guidance also points to the automated printer troubleshooter in the Get Help app.
    5. Remove and reinstall the printer
      • Go to Settings > Bluetooth & Devices > Printers & scanners.
      • Select the printer, then choose Remove.
      • After removal, select Add device and let Windows search for the printer again.
      • If Windows does not find it, select Add manually.
    6. Reinstall or update the driver
      • In Device Manager, right-click the printer and select Uninstall device.
      • Restart the PC, then reinstall the printer driver.
      • If the latest OEM driver still fails, try a generic in-box driver.
    7. Clear and restart the Print Spooler
      • Warning: this clears pending print jobs.
      • Search for services and open Services.
      • Double-click Print Spooler and select Stop.
      • In the taskbar search box, enter %WINDIR%\system32\spool\printers and delete all files in that folder.
      • Go back to Services, open Print Spooler again, select Start, set Startup Type to Automatic, and select OK.
    8. Print a test page
      • After reinstalling, print a test page to confirm the printer is working.
    If the printer works from other devices but not from this PC, that points more to a Windows printer setup, driver, or spooler problem on this computer than to the printer itself.
