Trouble calling Excel Data Analysis ToolPak functions from Access VBA
Rick Thackeray 0 Reputation points
2026-08-19T14:19:34.1433333+00:00
I am trying to run Excel's Data Analysis ToolPak functions from Access VBA, but I receive an error message: Application-Defined or Object-Defined error. Here is my code: objExcel.Run "ATPVBAEN.XLAM!Regress", objSheet.Range(rng_y), objSheet.Range(rng_x), objSheet.Range(rng_reg_out), True, True, 1, 0.95, True, True, False, False, False I start an instance of Excel with the CreateObject method in a Sub prior to the above line and pass a pointer to the function trying to access the toolpak.. The Excel created shows the Data Analysis ToolPak is loaded when checked under Options, but does not show on the Data toolbar ribbon. I have checked for the toolpak functions being loaded and they are. If I try doing the call against a fully qualified path to ATPBAEN.XLAM I get a message that effectively says I can't do that because of security considerations. If I start Excel from my taskbar shortcut, it shows the toolpak in the Data section. Any help would be greatly appreciated. Even if I could understand the differences in the way Excel is started, it would be helpful. Thank you. Rick
Microsoft 365 and Office | Access | For home | Windows
  1. Marcin Policht 108.1K Reputation points MVP Volunteer Moderator
    2026-08-19T15:23:43.9533333+00:00
    The likely issue is that CreateObject("Excel.Application") starts a separate Excel instance, and that instance does not necessarily load the Analysis ToolPak VBA add-in the same way as Excel started normally from the taskbar. Seeing the ToolPak enabled in Excel Options does not guarantee that ATPVBAEN.XLAM is loaded in your automation instance.
    Try loading the VBA add-in before calling Regress:
    Set objExcel = CreateObject("Excel.Application")
    objExcel.Visible = True
    Dim ai As Object
    For Each ai In objExcel.AddIns
        If InStr(1, ai.Name, "Analysis ToolPak - VBA", vbTextCompare) > 0 Then
            ai.Installed = True
            Exit For
        End If
    Next
    Then use your existing call:
    objExcel.Run "ATPVBAEN.XLAM!Regress", _
        objSheet.Range(rng_y), objSheet.Range(rng_x), _
        objSheet.Range(rng_reg_out), True, True, 1, 0.95, _
    Also verify that objSheet was created from the same objExcel instance. Do not use the full filesystem path to ATPVBAEN.XLAM; that can trigger Excel's security restrictions.
    The key difference is that Excel launched from the taskbar goes through the normal Excel startup process, while CreateObject creates a fresh automation instance with its own add-in state.
    If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    hth
    Marcin
