A desktop publishing application from Microsoft that focuses on page layout and graphic design.
Hello Glenn Tinturin
Were the instructions provided by the AI able to help you, or are you still unable to convert your Publisher files?
Please note that Microsoft’s PowerShell script is provided as a sample and may require modification and testing for your specific setup.
If the issue remains, please share the exact PowerShell script error message and command you used. Also confirm whether Publisher is installed and activated, and whether you can manually open and export one of the affected .pub files to PDF.
This information will help narrow down whether the problem is related to PowerShell, the file path, Publisher, or an existing PDF with the same name.
I look forward to your update and will be happy to guide you further.
