Microsoft project management software used to plan, manage, and communicate a project schedule and other information among workgroup members, project managers, and other stakeholders.
If the new laptop has no CD/DVD drive, copy the entire Project 2013 DVD to an ISO file or USB drive. Then copy the ISO/files to the new laptop and run setup.exe. Enter your original Project 2013 product key when prompted.
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
