Excel how do I lookup cells with more than 250 characters?
Laura McQuillan 0 Reputation points
2026-08-17T14:45:38.7133333+00:00
I wish to look up cells in sheet-1 in a list in sheet-2. The cells contain text with more then 250 characters.
I get the error #VALUE.
How do I overcome this?
Microsoft 365 and Office | Excel | For home | Other
  1. TaoLi 111.5K Reputation points Independent Advisor
    2026-08-17T15:21:04.2733333+00:00
    Hi
    This is a known VLOOKUP limitation. If the lookup text is longer than 255 characters, VLOOKUP can return #VALUE!. Microsoft recommends using INDEX + MATCH instead.
    For example, if Sheet1!A2 contains the long text, Sheet2 column A contains the text to search, and column B contains the value you want returned, try:
    =INDEX(Sheet2!$B$2:$B$1000,MATCH(TRUE,Sheet2!$A$2:$A$1000=Sheet1!A2,0))
    With Microsoft 365, just press Enter. With older Excel versions, press Ctrl+Shift+Enter.
    Microsoft’s explanation is here: https://support.microsoft.com/en-us/excel/how-to-correct-a-value-error-in-the-vlookup-function
    If you still get #N/A, make sure the two long text strings are exactly identical, including spaces or hidden characters.
