Correct - verify first, change only what is actually wrong, and let Netlogon re-register its SPNs. On the renamed DC, check the current SPNs:
setspn -L NEWDC
Then search for stale SPNs containing the old name:
setspn -Q */OLDDC
setspn -Q */OLDDC.contoso.com
Also check for duplicate SPNs:
setspn -X
If you find an obsolete SPN registered against the renamed DC, remove only that specific entry:
setspn -D HOST/OLDDC NEWDC
If a required SPN is genuinely missing, use -S, which checks for duplicates before adding it:
setspn -S HOST/NEWDC NEWDC
setspn -S HOST/NEWDC.contoso.com NEWDC
Afterward, restart Netlogon to trigger registration again:
net stop netlogon
net start netlogon
Finally, verify replication with:
repadmin /replsummary
Do not delete and recreate the entire SPN set manually. Domain Controllers have numerous automatically managed SPNs, and unnecessary changes can create additional Kerberos problems.
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
