A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
Try these steps in order:
- If the whole laptop screen is black:
- Press Windows + Ctrl + Shift + B to reset the graphics driver. A beep or screen flicker can indicate it worked.
- Press Windows + P, then press P again and Enter to cycle display modes in case Windows is sending video to the wrong screen.
- Press Ctrl + Alt + Del. If the security screen appears, Windows is still running.
- If nothing changes, hold the power button for 20 seconds to force a restart.
- If Windows works but PowerPoint shows a black screen, freezes, or stops responding:
- Check whether PowerPoint is busy with another process by looking at the status bar at the bottom of the PowerPoint window. If it is, wait for that task to finish.
- Start PowerPoint in Safe Mode:
- Open Start
- Type PowerPnt /safe
- Open PowerPoint
- If PowerPoint works in Safe Mode, disable add-ins:
- Go to File > Options > Add-Ins
- Select COM Add-ins
- Click Go
- Clear all checkboxes
- Click OK
- Restart PowerPoint
- Re-enable add-ins one at a time until the problem returns to find the conflicting add-in.
- Repair Office if PowerPoint still does not work:
- Close all Office apps.
- Open Control Panel > Programs and Features.
- Right-click Microsoft Office.
- Select Change > Repair.
- Check graphics and display-related causes:
- Install the latest Office updates.
- If PowerPoint crashes when using pictures or videos, update the Intel graphics driver, especially if the PC has an older Intel 510, 520, or 620 graphics driver.
- Check antivirus software:
- Make sure antivirus software is fully updated.
- If antivirus integrates with PowerPoint, it can cause performance problems. Disabling that integration may help. Warning: changing antivirus settings can make the PC more vulnerable.
- Change the default printer:
- Open Control Panel > Hardware and Sound.
- In the printers list, right-click Microsoft XPS Document Writer or Send to OneNote.
- Select Set as default printer.
- If the problem continues, try a selective startup to check whether another program is conflicting with PowerPoint.
