How to fix PowerPoint files embedded into Sharepoint displaying the bottom button panel again?
Mati Toming 20 Reputation points
2026-08-17T06:43:01.2+00:00
Files embedded onto Sharepoint page have undergone a change. Previously, all file types used (Word, Excel, PowerPoint) have always offered a black bar underneath the preview, allowing you to use a short panel of buttons that allow you to open the file on a new browser tab, for example. I've added an image to highlight using the colour Blue, to show how this looks with Excel type files.
As of last week, it seems this black bar is no longer available for PowerPoint type files, meaning you are only able to access the miniature size/version of the file, instead of being able to open it in a new tab via the panel - indicated the lack of the panel in Red for illustration purposes
It seems something has changed and I'd like to revert it - it's unclear if this is a Microsoft change, but no changes have been made on our Sharepoint as far as I'm aware.
SharePoint embedded files issue
Thank you for your support.
Kind regards,
Mati
Microsoft 365 and Office | PowerPoint | For business | Windows
  1. Ana Le 2,345 Reputation points Independent Advisor
    2026-08-17T06:54:14.91+00:00
    Based on the screenshot, it looks like the PowerPoint is being displayed through the SharePoint File and Media (File Viewer) web part.
    Microsoft’s current documentation indicates that files such as Word, Excel, and PowerPoint can be displayed through this web part, and that a toolbar is available when hovering over the file in view mode. The toolbar can include actions such as opening the file in a new window.
    Since the toolbar is still available for your Excel files but is missing specifically for PowerPoint files, I would first check whether this is limited to the PowerPoint viewer rather than a change to the SharePoint page configuration.
    Could you please try the following?
    1. Hover the mouse over the bottom area of the PowerPoint preview and check whether the toolbar appears.
    2. Open the same SharePoint page in an InPrivate/Incognito browser window and test the PowerPoint again.
    3. Test the page in another supported browser, if available.
    4. Add a different .pptx file to the same File and Media web part and check whether the toolbar is also missing.
    5. If possible, add the same PowerPoint file to a new test SharePoint page using a new File and Media web part and compare the result.
    If the toolbar is missing for multiple PowerPoint files and also occurs on a newly created File and Media web part, while Excel/Word files continue to show the toolbar, this would point more toward a change or issue in the PowerPoint viewing experience rather than a setting on the existing SharePoint page.
    At this time, I have not found a Microsoft-documented setting that allows the File and Media web part toolbar to be manually restored for PowerPoint files. Microsoft’s documentation still describes the toolbar as part of the viewer experience.
    If the behavior can be reproduced with a new PowerPoint file and a new File and Media web part, please provide the SharePoint page URL (if it can be shared), the browser/version being used, and whether the issue occurs for other users as well. That information would help determine whether this is a tenant/page-specific issue or a service-side change. For your reference: Use the File and Media web part | Microsoft Support
