Can we use standalone edge without edge sync to use SMTP relay over port 587
Priya Jayaraman 486 Reputation points
2026-08-17T05:53:03.9233333+00:00
Can we use standalone edge without edge sync to use SMTP relay over port 587.
Edge without exchange and installed in work group with no access to active directory server.
Only port 25 SMTP relay works or port 587 also works
Cheers
Priya
Exchange | Exchange Server | Development
  1. Dora-T 1,035 Reputation points Independent Advisor
    2026-08-17T06:48:59.7666667+00:00
    Hi Priya Jayaraman
    Based on my research, an Exchange Edge Transport server can be used without EdgeSync.
    For SMTP relay, Exchange supports Custom Receive connectors on Edge Transport servers, which can be configured with a specific local IP address and TCP port.
    However, port 587 is not the default Client Receive connector on Edge Transport. The Client usage type, which uses port 587 by default for authenticated SMTP submission, isn't available on Edge Transport servers.
    If you are considering port 587 for your SMTP relay scenario, you may want to review the Custom Receive connector configuration and authentication requirements to determine whether it fits your setup.
    For your reference:
    As this involves a more specialized Exchange configuration, you may also want to post your question in the Microsoft Tech Community. It’s a great platform for deeper technical discussions and for connecting with Exchange Server experts who may be able to provide more specific guidance for your scenario.
    I hope this helps.
    Note: Please follow the steps in the forum documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
