A professional diagramming tool that helps users visualize complex information through easy-to-understand diagrams.
Yes—there can be compatibility issues, and the key checks are installation technology, bitness, and update channel.
For Office Home and Business 2021 and Visio Standard 2024 on the same PC:
- Version compatibility
- Office 2021 and Visio 2024 are both version 16.0.
- Products with the same version can be installed together only if they use the same installation technology.
- Installation technology
- Office 2021 uses Click-to-Run.
- Visio 2024 compatibility with Microsoft 365 Apps is called out in the supported scenarios guidance, and side-by-side installs depend on matching installation technology.
- If one product is Click-to-Run and the other is MSI, they can't be installed together.
- Bitness must match
- Both products must be either 32-bit or 64-bit.
- A 32-bit Visio can't be installed with a 64-bit Office, and vice versa.
- Install order
- Earlier versions should be installed first.
- In this case, having Office 2021 already installed before adding Visio 2024 follows that guidance.
- Possible install behavior
- If setup detects an incompatible combination, installation can fail with messages such as products not being installable at the same time.
- In some mixed-version or overlapping-app scenarios, setup may also prompt to remove an existing product.
- Practical conclusion for this scenario
- Office Home and Business 2021 plus Visio Standard 2024 can work on the same computer if:
- both use Click-to-Run,
- both are the same 32-bit or 64-bit edition.
- If those do not match, installation issues are expected.
To verify the current Office installation before buying/installing Visio:
- Open an Office app such as Word.
- Go to File > Account > About Word.
- Check the version details and whether the installed edition is 32-bit or 64-bit.
- The installed Office details can also be checked in Control Panel > Programs and Features.
- Supported scenarios for installing different versions of Office, Project, and Visio on the same computer
- Install and use different versions of Office on the same PC
- "Following products can't be installed at the same time" error when installing or repairing Office
