Output on speakers for PC randomly varies
k flynn 0 Reputation points
2026-08-16T18:00:25.1+00:00
The sound output on my PC speakers randomly turns down briefly when I am streaming.
All looks to be in order with settings & only other devices attached to my PC is a wired printer & occasionally my iPhone.
How can I remedy this?
    2026-08-16T18:00:39.6166667+00:00
    For intermittent speaker volume drops while streaming, work through these steps in order:
    1. Check the active output device.
      • Select the Speakers icon on the taskbar.
      • Select the arrow next to the volume slider.
      • Confirm audio is playing to the intended speakers, not another device.
    2. Check system and app volume levels.
      • In Windows 11: Start > Settings > System > Sound > Volume mixer.
      • Make sure both System and the streaming app are turned up and not muted.
      • If the issue happens only while streaming, this helps confirm whether the app volume is dropping separately from system volume.
    3. Turn off audio enhancements.
      • Go to Start > Settings > System > Sound.
      • Under Output, select the speaker device in use.
      • Select Audio enhancements and turn them Off.
      • Test streaming again.
    4. Change the audio format.
      • Under Output, select the speaker device.
      • Select Advanced.
      • Under Default format, choose a different format and test again.
    5. Check hardware and connections.
      • Make sure speaker cables are firmly connected.
      • If speakers use USB, try a different USB port.
      • Make sure speakers are powered on and not muted.
      • If headphones were previously connected, unplug them and test the speakers again.
    6. Run the Windows audio troubleshooter.
      • Go to Start > Settings > System > Troubleshoot > Other troubleshooters.
      • In Audio, select Run.
    7. Update or reinstall the audio driver.
      • Open Device Manager.
      • Expand Sound, video and game controllers.
      • Right-click the audio device and select Update driver.
      • Restart the PC.
      • If the problem continues, uninstall the driver and reinstall the latest version from the device manufacturer’s website.
    8. Restart Windows audio services.
      • Select Start, type services.msc, and press Enter.
      • Right-click Windows Audio and select Restart.
      • Right-click Windows Audio Endpoint Builder and select Restart.
    Since the drop happens briefly during streaming, the most relevant first checks are Volume mixer, Audio enhancements, and the audio driver.
