how to fix sound distortion at higher volume settings
ronald artz 0 Reputation points
2026-08-15T21:33:00.8033333+00:00
I am getting significant sound distortion at high volume settings.
How do I fix this?
    2026-08-15T21:33:13.5933333+00:00
    Try these steps in order:
    1. Turn off audio enhancements.
      • In Windows 11: Start > Settings > System > Sound.
      • Under Output, select the audio device in use.
      • Select Audio enhancements and turn them off.
      • Test audio again at higher volume.
      • In Windows 10: right-click the Volume icon > Sounds > Playback tab > select the audio device > Properties > Enhancements tab > select Disable all enhancements > OK.
    2. Change the default audio format.
      • In Windows 11: Start > Settings > System > Sound > select the output device > Advanced > under Default format, choose a different format, then test.
      • In Windows 10: right-click the Volume icon > Sounds > Playback tab > select the audio device > Properties > Advanced tab > change Default format and test.
    3. Update or reinstall the audio driver.
      • Open Device Manager.
      • Expand Sound, video and game controllers.
      • Right-click the audio device and select Update driver.
      • Restart the PC.
      • If the issue continues, uninstall the audio driver and reinstall the latest version from the device manufacturer’s website.
    4. Restart Windows audio services.
      • Press Start, type services.msc, and press Enter.
      • Right-click Windows Audio and select Restart.
      • Right-click Windows Audio Endpoint Builder and select Restart.
      • Test audio again.
    5. If the issue is broader than distortion at high volume, run the Windows audio troubleshooter in the Get Help app.
