People on outlook will not load
Linda Morse 0 Reputation points
2026-08-15T13:04:50.98+00:00
I switched to the new Office email and left classic. My contacts did not load into people, then briefly at a different location with my laptop they loaded. Now that I am home, people just has a spinning wheel and I cannot access it at all.
    2026-08-15T13:05:03.61+00:00
    Since the issue started after switching to new Outlook, the most likely causes are either a new Outlook sync problem or contacts that were stored only in classic Outlook and did not move automatically.
    Try this in order:
    1. Check whether the contacts exist in Outlook on the web.
      • Open the People page in Outlook on the web.
      • If contacts appear there, the data is still in the mailbox and the problem is with the new Outlook app loading or syncing.
      • If contacts do not appear there, they may have been stored only in classic Outlook.
    2. Repair new Outlook.
      • Open Settings > Apps > Installed apps.
      • Find Outlook (new).
      • Select the three dots > Advanced options > Repair.
      • Restart Outlook and test People again.
    3. If People still spins, reset the app state from within new Outlook.
      • In new Outlook, go to Settings > General > Privacy and Data > Reset.
      • Then go to Settings > Accounts and remove and re-add the account to refresh sync.
    4. If contacts were local-only in classic Outlook, export and import them.
      • In classic Outlook, go to File > Open & Export > Import/Export.
      • Choose Export to a file > Comma Separated Values (CSV).
      • Export the Contacts (This computer only) folder.
      • In new Outlook, open People and import the CSV file.
    5. If People opens in a separate window when the main view spins, use that as a temporary workaround while repairing the app.
    What the results mean:
    • Contacts visible on the web = new Outlook client issue.
    • Contacts only in classic Outlook local folders = export/import is required.
    • People spins everywhere in new Outlook = repair, reset, and account re-add are the supported next steps.
