Problem with phone number
Đồng Văn Thái 20 Reputation points
2026-08-15T10:16:16.0733333+00:00
Hello Microsoft Rewards Support Team,
I am writing to request assistance with my Microsoft Rewards account ([Moderator's note: PII removed]@outlook.com.vn).
I am currently participating in Microsoft Rewards and accumulating points. However, I am facing a major issue:
In my account management settings, my account only has a @icloud.com email address linked, and there is completely no option or place for me to add or link a phone number to the account.
When I try to redeem my rewards, the system requires SMS verification. Because I cannot link a phone number beforehand, I am completely unable to receive a verification code and am blocked from completing the redemption process.
Could you please check my account status, or help me manually add a phone number / bypass this SMS restriction so that I can successfully redeem my rewards?
Thank you for your time and assistance.
Best regards
[Moved from Microsoft Security | Microsoft Authenticator]
Bing | Microsoft Rewards
Haytham-C 5,290 Reputation points Microsoft External Staff Moderator
2026-08-16T07:59:39.83+00:00
Hello Đồng Văn Thái
Thank you for reaching out, as of now, is currently removing the option to add/update phone number to your MSA account due to stop sending SMS codes as stated here and Microsoft would advise users to add an alternate login option such as a 6-digit code to your backup email or setting up a passkey for improve security. The picture below is on my testing environment and as you can see, the option to add/update phone number is no longer visible anymore
However, in order to redeem your rewards, there is workaround that you can try:
Use verification method with Bing app:
  • Download the Bing app to your mobile device > login to your Microsoft account then choose your Rewards then click Next:
    Media
  • On the next windows when it said verify your account, choose Verify with Bing app and a 6-digit code will show up, then it will redirect you to the redeem window, input the code and you shall receive your rewards:
Media (1)
  • The picture above is in my Android test environment, and it could be applied to IOS device too, so I hope that workaround can help you redeem your rewards.
If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
0 additional answers
