Troubleshoot Microphones
Jack Wilkins 0 Reputation points
2026-08-14T21:27:01.81+00:00
The Microphone works on some devices but not on all, can you troubleshoot the microphones and the Realtek Software?
    2026-08-14T21:27:26.7166667+00:00
    Use this Windows 10 troubleshooting path for a microphone that works in some apps or devices but not all.
    1. Check microphone privacy access.
      • Go to Start > Settings > Privacy > Microphone.
      • Turn on Allow apps to access your microphone.
      • Turn on Allow desktop apps to access your microphone.
      • If the device is a webcam with a mic, also check Start > Settings > Privacy > Camera and make sure camera access is on.
    2. Make sure the correct input device is selected.
      • Go to Start > Settings > System > Sound.
      • Under Input, confirm the intended microphone is selected in Choose your input device.
      • Speak into the mic and check Test your microphone. If the line moves, Windows is receiving audio.
    3. Raise the microphone level.
      • In Start > Settings > System > Sound, under Input, select Device Properties for the microphone.
      • Open the Levels tab.
      • Increase Microphone and Microphone Boost as needed, then select OK.
    4. If others cannot hear the microphone, verify basic device state.
      • Make sure the headset or microphone is connected correctly.
      • If the headset has a mute button, make sure it is not active.
      • If it is Bluetooth, make sure it is paired and connected.
    5. Run the Recording Audio troubleshooter.
      • Go to Settings > Update & Security > Troubleshoot > Additional troubleshooters.
      • Run Recording Audio.
    6. Reinstall the audio drivers if Windows is not detecting the microphone.
      • Warning: uninstalling drivers temporarily removes audio devices until Windows reinstalls them.
      • Right-click Start and open Device Manager.
      • Expand Sound, video and game controllers.
      • Right-click each audio device and select Uninstall device.
      • Check Delete the driver software for this device, then select Uninstall.
      • Restart the PC.
      • If Windows does not reinstall automatically, open Device Manager, right-click Sound, video and game controllers, and select Scan for hardware changes.
      • Then right-click the audio driver and select Update driver.
    7. For Realtek software behavior in third-party apps, try disabling audio enhancements.
      • Open the microphone properties from the recording device settings.
      • Turn off Enable audio enhancement if present.
      • If available, try changing the microphone sample rate and bit depth in the Advanced tab.
      • This is relevant when the microphone works in Windows tools such as Sound Recorder but not in non-Microsoft apps.
    8. If the issue continues, install the latest audio driver from the PC manufacturer.
      • This is especially relevant for Realtek-based systems after a clean Windows installation.
      • Restart after installation and test again in the affected apps.
    If the microphone works in Windows test pages or Sound Recorder but not in specific third-party apps, the most relevant checks are: privacy access, correct default input device, disabled audio enhancements, and updated manufacturer audio drivers.
