Excel COM Automation Fails with RPC_E_CALL_REJECTED and EXCEL.EXE Crash After Recent Office Update
Abhishek Mendon 0 Reputation points
2026-08-14T19:20:08.27+00:00
We have an intermittent Excel COM automation issue that started after recent Windows/Office updates.
Environment:
  • Windows Server 2022
  • Excel Version 16.0.20228.20186
  • PowerShell COM automation using New-Object -ComObject Excel.Application
  • Automation initiated remotely via SSH -> PowerShell
Symptoms:
  • Excel workbook opens successfully, then subsequent COM calls fail with:
RPC_E_CALL_REJECTED (0x80010001) - "Call was rejected by callee"
  • Occasionally cleanup fails with:
0x800AC472
  • Event Viewer shows EXCEL.EXE crashes:
Faulting module: mso98win32client.dll
Exception code: 0xc0000005
Example log:
Excel Object created
Opening workbook...
Excel workbook opened
ERROR: Call was rejected by callee. (0x80010001)
The same PowerShell script and workbook run successfully when executed interactively on the server, but intermittently fail when launched remotely through our automation process. This behavior began after the recent Office/Windows updates.
We would like to know if there are any known issues with Excel build 16.0.20228.20186 related to COM automation, RPC_E_CALL_REJECTED (0x80010001), mso98win32client.dll crashes, or non-interactive/server-side Excel automation.
Microsoft 365 and Office | Development | Other
  1. Ryan-N 15,565 Reputation points Microsoft External Staff Moderator
    2026-08-14T20:22:12.4766667+00:00
    Hi Abhishek,
    Welcome to the Microsoft Q&A forum.Thank you for sharing the detailed information.
    Based on your description, I understand that the issue only occurs when Excel is automated through a non-interactive session (SSH > PowerShell) and does not occur when the same script is executed in a direct interactive user session.
    This suggests that the root cause may be related to Office automation in an unattended environment, rather than the workbook file itself.
    At this time, we have not identified any publicly documented known issue specific to Excel build 16.0.20228.20186 that causes the RPC_E_CALL_REJECTED error or results in a crash of mso98win32client.dll.
    To further investigate the issue, could you please help check the following:
    1/ Run the same script in an interactive RDP session
    Instead of executing the script through SSH, please try running the same script within an interactive Remote Desktop (RDP) session and verify whether the issue still occurs.
    2/ Test with a different workbook
    Please create a new workbook containing only a few cells of simple data, then run the script again and check whether the issue persists.
    3/ Disable all Excel add-ins
    Please try disabling all Excel add-ins to rule out the possibility of an add-in conflict causing the issue.
    Once you have completed the steps above, please let me know the results so that I can continue assisting you and recommend more appropriate troubleshooting measures.
  2. Abhishek Mendon 0 Reputation points
    2026-08-17T13:12:25.9633333+00:00
    Just to clarify the process and the current issue.
    Our automated process does an ssh to the windows server and then runs a powershell script with parameters sent. This powershell script opens a excel file, refreshes the pivot data and then save a copy of the sheet. The windows server has an open session always with the ssh user logged in.
    Now the automated process is failing but if I RDP to the windows server and run the powershell script in a powershell cli then the script succeeds. After this when I run the automated process again for the same excel file the process runs fine. But if I try to run the automated process for a different excel sheet I see the failure again. I have to run the process manually on an RDP session for each excel file and then run the automated process again for the same excel file consecutively for it to complete successfully.
    We applied windows patches and did office update before this issue started happening.
