Static Web Apps custom domain stuck at RetrievingValidationToken, fails after 10 minutes — slice 7 only
Waseem Ansari, MD 20 Reputation points
2026-08-14T13:48:34.5433333+00:00
Adding a custom domain to any Azure Static Web App on slice 7 fails. The domain enters
RetrievingValidationToken, never advances to Validating, and times out to Failed at
about 10 minutes with:
"An unknown error has occurred while adding your custom domain. Please try again later."
An identical add on a slice 1 app succeeds in under 4 minutes. This looks like the
validation-token issuing service on slice 7 is broken.
WHAT I OBSERVED
Same tenant, same registrar, same parent domain. DNS verified correct at the
authoritative nameservers before every attempt.
App on slice 1 (*.1.azurestaticapps.net)
  RetrievingValidationToken -> Validating -> Ready in 3m54s   SUCCESS
App on slice 7 (*.7.azurestaticapps.net)
  RetrievingValidationToken -> (never reaches Validating) -> Failed at 10m17s
The slice 7 app already has a different custom domain in Ready state, bound
successfully a few days earlier. It can no longer bind a NEW one. So this is not a
broken or misconfigured resource — it is the slice.
In total, 7 hostnames failed across 2 different Static Web Apps in 2 different resource
groups, all on slice 7, all with the same state transition and the same 10-minute timeout.
REGRESSION WINDOW
Last successful custom domain bind on slice 7: 2026-08-10 17:07 UTC.
First failure: 2026-08-12 14:26 UTC.
Something appears to have changed in that ~46 hour window.
ALREADY RULED OUT (tested, not assumed)
  • DNS correctness — verified at the authoritative nameservers, 1.1.1.1, and Google DoH
  • DNS propagation / waiting longer
  • Conflicting A/AAAA/TXT records
  • CAA — no CAA records exist on the parent domain, so issuance is unrestricted
  • DNSSEC — no DS/DNSKEY records
  • Validation method — using cname-delegation; EnterpriseGradeCdnStatus is Disabled
  • Entry method — portal, az CLI, and raw ARM PUT all fail identically
  • The resource itself — a healthy app with a live custom domain fails the same way
  • Tier — Free and Standard both fail
  • Region — see below
WHY I CANNOT USE THE DOCUMENTED WORKAROUND
The usual advice for a stuck custom domain binding is to recreate the Static Web App
until it lands on a different slice. I created 6 new Static Web Apps across 2 regions
(West US 2 and East US) on the Free tier. Every single one was allocated to slice 7.
New allocations appear to be pinned there, so recreating cannot escape the problem.
CORRELATION IDs (all ResourceOperationFailure, terminal provisioning state 'Failed')
bf05647b-6c01-4655-b297-83968f7a892d
b975eb4b-7cdf-4298-9ac1-16286ede0856
cea97715-e258-4b3c-aa04-f3ba36bebd59
40b9d0df-f00d-4c44-bca5-782ef86ee330
7b44cf72-ad76-4454-b5e1-665fc3780c56
QUESTIONS
  1. Is there a known issue with validation-token issuance on slice 7?
  2. Is there any way to influence which slice a new Static Web App is allocated to, given region and tier both had no effect?
  3. Two custom domain entries are wedged in "Deleting" state. Delete via portal, az CLI, and raw ARM DELETE all return success but never reconcile. Is there any customer-side way to release these, or does it require backend intervention?
Happy to share resource IDs and the subscription privately if that helps.
Azure Static Web Apps
An Azure service that provides streamlined full-stack web app development.
TP 163.1K Reputation points Volunteer Moderator
2026-08-14T13:55:31.8933333+00:00
Please retry deleting your custom domain(s) via the portal. There was an issue (details below) last few days that has been mitigated.
In regards to adding custom domain, have you tried again today? I'm asking because there may be a separate issue that is blocking you from adding custom domain on slice 7.
Below is excerpt from Post Incident Review (PIR) DZXC-65Z:
What happened?
Between 14:30 UTC on 11 August 2026 and 15:50 UTC on 13 August 2026, a platform issue resulted in an impact to the Azure Static Web Apps service in multiple regions. Impacted customers may have experienced failures or delays when deleting or adding custom domains for Azure Static Web Apps resources hosted in the affected regions. The impact was limited to a subset of customers.
What went wrong, and why?
A platform issue caused an increase in processing backlog for operations responsible for managing custom domain configuration changes. As a result, requests to delete or add custom domains were delayed or failed for a subset of Azure Static Web Apps customers. The issue was mitigated after service processing queues recovered to normal operating levels and pending operations were cleared.
How did we respond?
  • 14:30 UTC on 11 August 2026 – Customer impact began.
  • 13:04 UTC on 12 August 2026 – The issue was identified through customer reports of failures and delays when deleting custom domains.
  • 23:28 UTC on 12 August 2026 – We identified elevated service processing queues as a contributing factor and initiated mitigation activities.
  • 15:50 UTC on 13 August 2026 – Service processing queues recovered to normal levels and the impact was mitigated. Customers were advised to retry previously failed operations.
What happens next?
  • This Mitigation Statement is the final communication for this incident. For details about which Azure incidents qualify for which Post Incident Reviews (PIRs), refer to https://aka.ms/AzurePIRs
  • The impact times above represent the full incident duration, so are not specific to any individual customer. Actual impact to service availability may vary between customers and resources – for guidance on implementing monitoring to understand granular impact: https://aka.ms/AzPIR/Monitoring
  • To stay informed about future Azure service issues, make sure that you configure and maintain Azure Service Health alerts – these can trigger emails, SMS, push notifications, webhooks, and more: https://aka.ms/ash-alerts
  • For broader guidance on preparing for cloud incidents, refer to https://aka.ms/incidentreadiness
Please click Accept Answer and upvote if the above was helpful.
Thanks.
-TP
0 additional answers
