How to reset without the BitLocker Recovery Key?
Matthew Zakrzewski 0 Reputation points
2026-08-14T12:06:56.62+00:00
I have a laptop that was added with the same name as another laptop in Active Directory. Due to this I cannot get into the organization's domain. I have tried to reset the laptop with the BitLocker recovery key. Unfortunately, since there are multiple laptops with this name, I'm not able to get the BitLocker recovery key. And I'm not able to progress pass the BitLocker recovery screen. Please tell me how to proceed
Windows for business | Windows Client for IT Pros | Devices and deployment | Recovery key
  1. Allan Solomon Mejia 7,995 Reputation points
    2026-08-14T19:27:41.1633333+00:00
    Hello @Matthew Zakrzewski
    The duplicate computer name shouldn't prevent you from identifying the correct BitLocker key. Use the Recovery Key ID displayed on the BitLocker recovery screen rather than relying only on the computer name.
    For an AD DS-joined device, an administrator can use Active Directory Users and Computers (ADUC) with the BitLocker Recovery Password Viewer installed. Right-click the domain and select Find BitLocker Recovery Password, then enter the first eight characters of the Recovery Key ID shown on the affected laptop. This lets you locate the matching recovery password even when multiple computer objects have similar or duplicate names.
    Also check whether the device is hybrid/Microsoft Entra joined or Intune-managed, because its recovery key might be stored in Microsoft Entra ID or Intune rather, or in addition to on-premises AD.
    If the correct recovery key cannot be found in AD DS, Entra ID, Intune, or another previously configured recovery location, BitLocker encryption cannot simply be bypassed or reset while preserving the encrypted data. That's an intentional security property of BitLocker. In that situation, if the existing data isn't required, the practical option is to wipe/reimage the drive and reinstall Windows.
    Before doing that, I'd strongly recommend searching AD using the Recovery Key ID first, since AD can retain multiple recovery-password objects for a computer.
    Please "Accept the Answer" if this information helped you. This will help us and others in the community as well.
