How to fix character encoding issues for Spanish special characters (Ñ / ñ) on web tools?
Sartaj Jon 0 Reputation points
2026-08-14T05:58:06.4233333+00:00
​_Hi Microsoft Community,_
​_I am testing a web character tool built for quick Spanish character insertion (e.g., https://enyecopypaste.com/_
​_I am encountering a slight rendering/encoding glitch when copying special characters like Ñ or ñ across different Windows browsers (Edge vs Chrome)._
​_1. What is the recommended UTF-8 meta setup or IIS/server header configuration to ensure special characters paste seamlessly without breaking formatting?_
2. Are there specific Windows keyboard/clipboard API standards I should follow for web-based copy utility tools?
​_Any insights or best practices from web developers here would be greatly appreciated!_
Microsoft Edge | Other | Windows 10
  1. Emma1-N 12,030 Reputation points Microsoft External Staff Moderator
    2026-08-14T23:38:15.1633333+00:00
    Welcome Sartaj Jon,
    For Spanish characters such as Ñ and ñ, the most reliable approach is to ensure that UTF-8 is used consistently throughout the entire data flow (HTML page, server response, clipboard handling, and storage). UTF-8 is recommended as the preferred encoding for web applications and international text support.
    Use UTF-8 code pages in Windows apps - Windows apps | Microsoft Learn,
    How to: Select an Encoding for ASP.NET Web Page Globalization | Microsoft Learn
    1. UTF-8 page and server configuration
    • In your HTML document, place the following near the beginning of the <head> section: <meta charset="utf-8">
    • HTML5 specifies UTF-8 as the standard encoding declaration for web pages
    • Also verify that your server sends a UTF-8 content type header, for example: Content-Type: text/html; charset=utf-8
    • Explicitly declaring the charset helps browsers interpret special characters correctly.
    • For ASP.NET/IIS applications, you can also configure UTF-8 in web.config:
     <globalization
        requestEncoding="utf-8"
        responseEncoding="utf-8"
        fileEncoding="utf-8" />
    1. Clipboard and copy functionality
    For web-based copy tools, Microsoft Edge and other modern browsers support the Clipboard API. Microsoft and browser standards recommend using this modern API instead of older copy methods: await navigator.clipboard.writeText("Ñ");
    The Clipboard API works with Unicode text and is generally the preferred approach for multilingual content.
    1. Additional checks
    If the issue occurs only after pasting into another application:
    • Verify that the destination application also supports Unicode/UTF-8.
    • Check whether the copied text is being transformed by JavaScript before it is placed on the clipboard.
    • Test the same character in Edge InPrivate mode to rule out extension interference.
    If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
