Can Teams notifications ring late? (When a notification occurs later than the actual time the message was received)
Harrison Maya 0 Reputation points
2026-08-14T00:52:43.3233333+00:00
The other person sent me a Teams message, but the notification rang later than the time it was sent, so I ended up replying late.
I confirmed that the other person sent me Teams at 12:50, 12:51, and 13:44, and that I received a notification at 13:45.
Someone else also sent me a Teams message at 13:02, and I received notifications for everyone at 13:45.
The notification sounded late on both PC and mobile, and at the time, both PC and mobile were in power saving mode.
We confirmed that notifications may be delayed on PCs when in power-saving mode, but if notifications did not sound on mobile, it is mostly an issue on Microsoft's end.
However, my PC and mobile did not ring.
Even if there are no officially announced MS issues, can notifications often occur later than the actual time the message was received?
Microsoft Teams | Microsoft Teams for business | Settings | Configure notifications
    2026-08-14T00:52:57.7366667+00:00
    Yes. Teams notifications can arrive later than the message time.
    The supported information is:
    • On mobile, Teams sends notifications by default, but mobile notification behavior can change based on whether Teams detects activity on desktop or web.
    • Mobile notifications resume only after Teams detects that desktop or web has been inactive for a few minutes when notification blocking is configured for activity on other devices.
    • Call notifications are treated differently and are still sent to mobile even when active on desktop.
    • On desktop and mobile, notification behavior can also be affected by notification settings such as muting, showing notifications during meetings, sounds, and device-level notification settings.
    • For calls across devices, Microsoft states other devices may still ring briefly because of signaling latency or sync delay. That confirms notification timing across devices is not always exact.
    For the scenario described, a delayed notification at 13:45 for messages sent earlier is consistent with Teams notification timing not always matching the exact message receipt time, especially when device state or notification handling delays delivery.
    Checks that are supported by the available guidance:
    1. On desktop Teams, go to Settings and more > Settings > Notifications and activity.
    2. In General, review whether notifications are muted and whether notifications are allowed during calls and meetings.
    3. On mobile Teams, go to the profile picture > Notifications.
    4. Check whether Show notifications is on.
    5. Under Block notifications, review When active on other devices, When in meetings, and In-app notifications.
    6. In the device settings, confirm Teams notifications are allowed.
    If the issue continues on mobile, the documented next step is to send feedback from the Teams mobile app: profile picture > Settings > Help and feedback > Send feedback.
  2. Teddie Dang 1,265 Reputation points Independent Advisor
    2026-08-14T01:56:20.5233333+00:00
    Hi @Harrison Maya
    Teams notifications can sometimes be delivered later than the actual message timestamp, even when there is no officially reported Microsoft service incident. Notification delivery can be affected by device power-saving states, background app restrictions, network conditions, synchronization between Teams clients, and OS-level notification handling.
    Since the notification delay occurred on both the PC and mobile device, it may indicate a temporary delay in notification delivery or processing. While power-saving mode on a PC is a known factor that can cause delayed notifications, mobile devices can also experience notification delays due to battery optimization, background processing restrictions, network transitions, or push-notification timing.
    To reduce the possibility of this happening again, I recommend the following:
    • Temporarily disable power-saving mode on both the PC and mobile device and test Teams notifications again. If notifications work normally afterward, power management may have contributed to the delay.
    • Check Teams notification settings by going to Teams > Settings > Notifications and activity. Make sure chat notifications and notification sounds are enabled. You can also use the Test notification option if available.
    • Check the mobile device's notification permissions and make sure Teams is allowed to send notifications and play sounds.
    • Check battery optimization/background restrictions for Teams on the mobile device. If Teams is restricted from running in the background, notifications may be delayed. On Android in particular, consider excluding Teams from battery optimization.
    • Test using 5G/mobile data instead of Wi-Fi. If the notification delay occurs while connected to Wi-Fi, temporarily switch to 5G and test again. If notifications work normally over 5G but are delayed over Wi-Fi, the Wi-Fi/network environment may be contributing to the issue. You can also perform the reverse test.
    • Update and restart Teams on both devices. Completely close Teams, reopen it, and make sure the latest version is installed.
    • Perform a controlled test. Have someone send several Teams messages at different times while both devices are awake and not in power-saving mode. Record the message timestamp and the exact time the notification appears. This can help determine whether the delay is reproducible.
    If the notifications are still delayed on both PC and mobile after these checks, particularly if multiple messages again generate notifications together several minutes later, the issue may be related to a temporary Teams notification/push-delivery problem. In that situation, I recommend reporting the issue through Teams feedback and including the exact message times and notification times. In the mobile app tap your profile picture in the top left of the app > Settings > Help and feedback > Send feedback.
    If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
    Note: Please follow the steps in the forum documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
