I have an issue with Custom Domains lingering out there after being deleted
Joseph 20 Reputation points
2026-08-13T18:49:50.57+00:00
I am trying to create a custom domain for a Static Web Application, I created an entry and it failed validation and set in the failed state for over 24 hours. I went into the custom domains and tried to delete it, however it got stuck in the deleting state. It has been sitting in that state for the past 12 hours. Is there a way to clear that on the back end? or can Support run a script on the back end to clear it out.
Azure Static Web Apps
An Azure service that provides streamlined full-stack web app development.
TP 163.1K Reputation points Volunteer Moderator
2026-08-13T18:52:52.4866667+00:00
Hi Joseph,
Can you retry deleting your custom domain now? I just retried mine and it successfully deleted after about 2-3 minutes. Previously it had been stuck for many hours.
Below is latest update from the Service issue DZXC-65Z:
Service: Static Web Apps
Region: Global
Event tags: --
Impact Statement: Starting at 14:30 UTC on 11 August 2026, you have been identified as an affected customer using Azure Static Web Apps in multiple regions who may experience failures or delays when deleting custom domains for resources hosted in the region. At this time, the impact is limited to a subset of customers.
Current Status: Our teams have completed mitigation actions and are currently monitoring recovery progress. The issue was attributed to a backlog in the job queue responsible for custom domain deletion operations, which caused deployment requests to time out. Mitigation efforts included reducing the batch size of operations and stopping specific operations to accelerate queue recovery. Current telemetry indicates that the queue backlog is decreasing rapidly and is expected to reach a healthy state shortly.
Initial assessments indicate that custom domain creation and update workflows remain healthy, with the impact limited to delayed or failed custom domain deletion requests while the backlog was present.
We are validating recovery by monitoring system performance and confirming successful retries from affected customers.
The next update will be provided in 02 hours, or as events warrant.
Please click Accept Answer and upvote if the above was helpful.
Thanks.
-TP
1 additional answer
  1. Praneeth Maddali 12,670 Reputation points Microsoft External Staff Moderator
    2026-08-13T18:55:27.8566667+00:00
    Hi @Joseph
    Thank you for your patience while we looked into this.
    We have received confirmation that mitigation has been applied, and your custom domain issue should now be resolved. Could you please retry the operation and verify whether everything is working as expected?
    If you are still experiencing any issues, please reply with an update and any relevant details. We will be happy to continue assisting you and investigate further if needed.
    We look forward to hearing back from you.
    If the answer is helpful,  Please do click "Accept the answer” and Yes, this can be beneficial to other community members.
    If you have any other questions, let me know in the "comments" and I would be happy to help you
