How do I adjust a custom low disk space monitor
John Ingram 0 Reputation points
2026-08-13T15:19:49.32+00:00
How do I adjust a custom low disk space monitor, that is current sending alerts to customer for low disk space issues?
System Center Operations Manager
A family of System Center products that provide infrastructure monitoring, help ensure the predictable performance and availability of vital applications, and offer comprehensive monitoring for datacenters and cloud, both private and public.
  1. SChalakov 10,861 Reputation points MVP Volunteer Moderator
    2026-08-14T08:00:19.2633333+00:00
    Hi
    It depends on how this custom disk space monitor was created, so first we need a little more information.
    Could you please check the following?
    1. Open the monitor in the SCOM console.
    2. Right-click it and select Overrides → Override the Monitor.
    3. Tell us what settings you see there, or simply post a screenshot.
    The most important question is whether you can see settings related to disk space, for example:
    • Free Space %
    • Free Space MB
    • Threshold
    • Warning/Critical value
    If you can see such values, then this is probably easy: you can create an override and change the disk-space threshold without changing the monitor itself.
    If you cannot see any disk-space threshold in the Overrides window, then the value may have been built directly into the custom monitor. In that case, the monitor itself may need to be changed.
    It would also help if you could tell us:
    • What SCOM version are you using?
    • What exactly do you want to change? For example, alert at 10% free space instead of 15%?
    • Was this monitor created by you, by your company, or by somebody else?
    • If possible, post a screenshot of the monitor properties and the available overrides.
    Once we see the available override settings, we can tell you exactly what needs to be changed.
    Important: Do not start modifying the Management Pack XML yet. First check whether the required setting is already available as an override — in many cases that is all you need.
    Regards
    "If my response was useful, please consider marking it as the answer. It keeps the forum clean, structured, and more helpful for everyone. Thank you for supporting the community."
