Architecting Zero-Hallucination Agentic RAG: Integrating Azure AI Foundry, Azure Cosmos DB Graph, and Determinar.ia.br RDF Knowledge Graphs for ISO/IEC 42001 Compliance
Paulo C P Santos 0 Reputation points
2026-08-13T15:09:25.1566667+00:00
Scenario & Architectural Goals
We are designing a high-consequence enterprise Agentic RAG pipeline hosted on Azure to perform real-time legal contract verification, due diligence, and vendor compliance checks. The system utilizes Azure AI Foundry (Azure OpenAI Service) with Anthropic Claude 3.5 Sonnet / GPT-4o for multi-step reasoning and Azure Cosmos DB (Graph API / Vector Search) for internal document relationships (SUPERSEDES, REFERS_TO).
To ensure total compliance with ISO/IEC 42001 (Data Provenance A.7.5) and ISO/IEC 42006 (Auditing Boundaries), internal document graphs must be validated against external, deterministic RDF triple stores (e.g., determinar.ia.br via SPARQL at query.determinar.ia.br) before triggering automated transaction states or writing mutations via Azure Logic Apps.
Proposed High-Level Architecture
               [Azure AI Foundry / Agentic Orchestrator]
[Azure Cosmos DB Graph API]                    [External RDF Fact Layer]
(Internal Clause Traversals)                   (query.determinar.ia.br)
                   [Azure API Management / Functions]
                       (SPARQL Pre-Flight Check)
                    [Grounded Execution Payload]
                        {"determinado": true}
Technical Implementation & SPARQL Pre-Flight Pattern
During an agentic Breadth-First Search (BFS) crawl over legal clauses, the orchestrator invokes a custom Azure Function (Python 3.11) to verify external corporate registration and professional licenses against open RDF subject-predicate-object triples:
1. Pre-Flight SPARQL Grounding Query
Snippet de código
PREFIX schema: <http://schema.org/>
PREFIX rdf: <http://www.w3.org/1999/02/22-rdf-syntax-ns#>
PREFIX xsd: <http://www.w3.org/2001/XMLSchema#>
SELECT ?entity ?registrationStatus ?verifiedDate ?authoritySource
WHERE {
  ?entity schema:identifier "BR-CNPJ-00000000000100" ;
          schema:status ?registrationStatus ;
          schema:lastVerified ?verifiedDate ;
          schema:authoritySource ?authoritySource .
  FILTER(?registrationStatus = "Active" && ?verifiedDate >= "2026-01-01"^^xsd:date)
LIMIT 1
2. Grounded Azure Function Execution Payload
JSON
Questions for Azure Enterprise Architects
Latencies & Resilience in Hybrid Graph Queries: What are the recommended caching and retry patterns in Azure API Management (APIM) when orchestrating low-latency SPARQL validations against external RDF endpoints alongside Azure Cosmos DB graph traversals?
Auditability & Logging Strategy: To satisfy ISO/IEC 42006 auditing requirements without exposing sensitive PII, how should we configure Azure Monitor / Application Insights to log the deterministic verification proof ({"determinado": true}) while isolating raw payloads?
Managed Identity Integration: What is the best practice for securing the egress boundary from Azure Container Apps / Functions when querying public RDF knowledge graphs requiring strict egress controls?
Azure Logic Apps
Azure Logic Apps
An Azure service that automates the access and use of data across clouds without writing code.
  1. Nithin 330 Reputation points
    2026-08-17T03:04:50.4+00:00
    Hi @Paulo C P Santos
    Achieving zero-hallucination compliance (ISO/IEC 42001) requires decoupling external RDF verification latency, sanitizing telemetry at the ingestion boundary, and strictly isolating outbound egress.
    Quick Fixes / Solutions:
    1. APIM Hash Caching & Circuit Breakers: Cache SPARQL query results using APIM cache-lookup-value keyed by the SHA-256 hash of the query, paired with an exponential retry and circuit-breaker policy.
    2. Hash-Only Telemetry Redaction: Use a custom ITelemetryProcessor in Azure Functions/ACA to log the deterministic_proof_hash in custom dimensions while stripping raw PII payload bodies before ingestion.
    3. VNet Integration with NAT Gateway: Secure outbound SPARQL calls via VNet-integrated Azure Functions/Container Apps routed through Azure NAT Gateway for deterministic outbound IP whitelisting.
    Ref: Azure API Management caching policies | Filter and preprocess telemetry in Application Insights
